A little cheesy but added 3M carbon fiber vinyl wrap to the bowties. Matching the tungsten metallic paint is difficult which is why I went with this.
Not cheesy. Looks sharp. Was pondering doing the same to my Tungsten. The vinyl stick pretty well to the bumpy surface of the bowtie?
Edited by tootall87
  • Like 3
^^^ +1. Have some left over from a couple years ago just not sure how it would stick so would love to know!
It seemed very sticky while applying it and while removing the excess. A video I watched claimed after two years it is holding up like day 1 and others say after 1 year it still looks great, so I am expecting it to last at least a year. If you are worried about the stickiness, one video mentioned using 3M primer that is supposed to help with adhesion but it is probably not necessary.
Finally got my truck back after being at the Dealership for a week. Bumper was repainted, baked, put back on and clear bra installed. Came out real nice too, worth the wait
Had 3 of my windows replaced under warranty. Had a bunch of scratches down them, must have had dirt and rocks inside the door panel. They gave me a 2015 4.3L V6 for the day to use. Definitely didn't feel like my 6.2L but it had more power than I expected.
Not just today, but over the last few days I've been working on colormatching the chrome trim in the guage cluster
7BE0720E-F60C-4055-B70A-3BAD94B4F04D_zps
Drove around like this for the last 2 days
D8014860-267B-4100-BAD0-3805BDDD451C_zps
But here's the end results. Definitely worth it. It's easy to remove the trim, but it's a PITA at the same time
B88A3319-FD9A-4167-8C44-4945C118B64A_zps
BF3729DB-1DA1-42CD-9E49-6A20B32022E2_zps
B3362DEF-58C0-4795-8A8B-A796A168F144_zps
Last picture has a sneak for the next small interior project[emoji57] already got it in place, just need to straighten it up before I get a better picture of it
Also want to say thanks to Tgawly for giving me the idea and the instructions to get the guage cluster open and remove the trim
Edited by Mike1220
  • Like 4
Sorry, but your SIERRA the "E" is lower than the "R"'s on the glove box door
Yep, mentioned in my last post it wasn't done yet haha. I'm hopefully going to straighten it all up and finish it up later today. Might even ditch the idea for Z71 emblem.
We all know it was authentic Mike1220 when he includes the feet in the picture
  • Like 3
I don't think it looks "cheezy" at all. Looks great with your truck color.
I love the way the color matched gauges look! I want to do something about the chrome there also but I'm scared to start prying stuff lol
Bro you should of done a video on how to remove it. Now I want to take that idea from you haha.
Lol it's not hard. Just tedious. Just have to lift up to PPP off the dash piece above the cluster (it's just clipped in) then remove 3 screws and put the gear shifter down to manual and the steering wheel all the way down and remove the trim piece that sits in between the steering wheel and the guage trim. Then undo 4 more screws to free the cluster and there are 4 tabs (2 top and 2 bottom) that you'll need to push to release the front of the cluster. Don't try to pull lens off the cluster cause it's not meant to be removed! Once you have the front of the cluster off the trim is self explanatory from there. Just be careful not to fight it too much as no one would want to scratch up the inside of the lens.
Now I challenge you to do the chrome around the steering wheel emblem and the emblem itself. Once you finish that, go ahead & get a plane ticket to Cali and do this all for me. Please & thanks.
I would keep the GMC as is inside, it looks nice with the 2 colours.
The chrome bezel just prys off as it is just taped on
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
