Not quite into the sun but gives you an idea
Sent from my iPhone 6+
My strip goes farther down. All the way to the end of the black material around the mirror
I thought about going further but that's as far as you can legally go in Utah so I just went with that. Even though my windshield is tinted, I didn't want to draw any more attention.
6000k hids and 5000k led fogs worked well and matched nice!!! d9e97cf2623747bfe76ed6871940ce8f.jpg775e212d2d5ccaf22e93da1c497b43ad.jpg
Sent from my SM-G900W8 using Tapatalk
Ya mine is about the same as "Roidz". I'm guessing it depends on state law. When they asked me the % I wanted the brow I said the darkest I can go that's legal and a guy there said he thought since it's just the strip that it didn't matter how dark it was in NC. So you could put a vinyl strip on the top if you wanted. My OCD wanted it at least as low as the bottom of the black part where the mirror is, but seeing how low it looks I'm fine with it being where it is.
Ehh I didn't care about legal because well my truck is already illegal with 5% all around haha
Where did you see it? lol
The 1977 movie Close Encounters. LOL The scene where the UFO comes up behind Richard Dreyfuss at the R/R crossing. Awesome truck.
MGK......
Fan or not a fan?
Finally got my gauge inside the custom pod. Waiting for the Z71 logo faceplate arrives.
Does it display anything else beside MPH and RPM? If not it just seems like its a little redundant to have a secondary rpm and mph readout.
it has well over 100 parameters that you can choose from. As I just got my gauge and still trying to figure it out those other parameters. ;)
That is pretty dang cool. Smart way to use space and it looks as if GM put it there. Good job!
Sent by a simpleton struggling to operate an iPhone.
Washed, clayed, and waxed. Switched the chrome mirror caps out with summit white ones earlier this week. Looks so much better.
In other news, if anyone wants chrome mirror caps, I'll sell you mine.
Installed a stainless steel Magnaflow exhaust tip. 2.75" inlet, 3.5" outlet, 12" long. Angled, rolled tip. Wish I could find one in black but nobody makes one!
Also bought some Husky Contour floor mats, front and rear. I just put them over the stock "All weather" GMC rubber mats. Fits pretty good, but I don't know if I should take the rubber mats off and just sell em. I also have the carpet mats that I don't know what to do with. Maybe put the carpet mats under husky's and sell the rubber mats.
Anyways, here are some pics. :)
Next step is to get rid of the chrome running boards and get some black ones. Maybe get colour matched mirror caps and door handles as well.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
