Looks awesome im about to do the z71 bumper swap too. I really like the painted parts dude. Im Kajun504 on instagram
Sent from my LG-D850 using Tapatalk
Oh yea I know you lol. Thanks man, is coming along. I already have it on the truck, I'm just touching up my Headlights and grill.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
she's finally done. New colormatched bumper, skid plate and cap. Touched up my black grill, I still need to do the bowtie white and not to sold ok the black Headlights. Might go back to white next weekend when I install switchback leds
DROPKICK Edition
DROPKICK Edition
Looks like a storm trooper from star wars!
Finally got some more pictures not a good camara guy and no filter reverse and cargo lights d8e03ced2dac4ca0fcb93aaee82b434b.jpg9e181fe24d0308993c375944b38b7538.jpg
Then took a snap of My morimoto 6000k hid set up still love it 997e7f61e257061c82b1ab0c91acfc45.jpged49be5bbe2ba35c783a8cad980c8215.jpg
Sent from my SM-G900W8 using Tapatalk
Just got it out of the package my nfab light bar mount looks awesome and great quality! cd6165b5e5aa3ba77baaea1946124dab.jpgb85f66459917c703e815f2a37281e2ca.jpg93b9ec3aaea9d0c8a78bef7673ad7083.jpg21b7e1c16bdabc8a7b595bc04eb8c21f.jpg
Your headlight is shining a bit high, you should lower them!
Which mount did you get looks nice
Hmm there adjustment is where it should be.. Probably to blame is my leveling kit
WE need more photo's with lite bar install ? Looking good . HOW would a Midnite Edition look with a 2" leveling kit ??? looking for ideals .
Edited by tahoe08
Just waiting for my light bar to show up won't be shipped until next week but anxious to install it! And if it helps I can show you my truck on a 2.5 inch level? 7fcbcb54d7efb10307db9a556870e3c8.jpg
Anyone know what this top wire is for? The bottom two harnesses are for the light control and dim switch' the top wire was just seated in a blank clip on the back...
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
