The bars I added are for increased lighting in the rear when hooking up and loading my trailer as well as just backing up the driveway at night now that the windows are tinted. They've greatly increased visibility, both in the mirrors and with the backup cam.
Very clever idea, can't wait to see picks..
Sent from my SG Note 4 on Tapatalk
Installed my custom "Bullet" billet antenna.
You mind posting his ig name. Id like to look into one of these.
Yeah not a problem it's @billet_by_luz
Little lights with a lot of output...
Hey man,
First off, that is once sick install. I like the way you mounted them. Secondly, would it be possible for you to put up some pics from the inside of your cab looking out the back window. lastly, how does it look from your back up camera..(sorry im assuming you have one, if not would this still be something that you would've done) thanks man.
Thanks! I'll grab some more tomorrow. I do have a backup camera and even without it I would've done this in a heartbeat. With tinted windows it's still better than stock with no tint when looking out the side mirrors. Best part is you can't even see the lights until you get pretty far back or pretty low.
so the additional lighting doesn't flood out the view of your camera on the screen when backing up? Also, do you have a website for the LEDs that you used, and I'd like to pick your brain as far as how you went about installing....Thanks
Info on light pods?!
Got these installed today. Tapped the relay into the reverse power, and made a secondary hidden switch for when I need them while working/camping. I went for the most descreet look I could as I dislike how the pods hanging down looks. total cost was about 130$ cad and 2 hours.
http://www.amazon.ca/gp/product/B00NTPSLZ4?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
  • Like 3
Those look awesome! Going to have to put that on my to-do list. Unfortunately I think you got the last pair. Clicked on the link and they are sold out. I'm sure there's something else out there that will work.
Out of curiosity, do you know if these are small enough to mount on either side of the hitch? I circled the area in the picture below.
open the link and replace the .ca with .com
If you dont tow anything you could mount them there but they will be in the way of safety chains.
Looked under mine, I'd have to go further out to the sides but it's a perfect spot...
I didn't even think of that. I guess my mind doesn't process everything when I'm sitting at my desk at the office.
Any chance you could post some close up pictures of how you mounted them?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
