Did the diode reverse + cargo light mod. Now my cargo lights turn on when in reverse and when I unlock the truck with the fob. Love it!!! Gonna be great for the moments when you need to check your load and have the keys in your pocket or when hanging out by the truck and want to add some light without climbing in. Also seems to help a little bit with adding vision when using the back up camera.
I fall more in love with this truck everyday.
link to this mod plz. I did the fogs and brights mod. I have an extra diode left.
Installed my new tow mirrors.
Will have to go to a shop and get them hard wired though, as I couldn't get the clearance lamps to work.
For reverse and cargo you connect #26 in the brown harness (reverse lights) to #26 in the pink harness (cargo lights), with the band on the diode closest to the #26 wire in the pink harness.
I didn't even think of that. I guess my mind doesn't process everything when I'm sitting at my desk at the office.
Any chance you could post some close up pictures of how you mounted them?
Self tapping bolts, right into the hitch. put them at a slightly outward angle and screwed em in. then made up my wire harness and hooked it all up
This is through the tint on the front drivers window.
I drilled and tapped the hitch for a mount and tapped into the factory backup lights for power.
Finished installing the new bumpers. I like the way they turned out.
Sent from my SM-G920V using Tapatalk
Truck is Sick!! Nice job..
Sent from my SG Note 4 on Tapatalk
First of all nice job. Secondly, does your pods come on only in reverse, or did you attach a switch so that you can turn them on individually? Could you provide a parts list that you used for mounting? Thanks
Thanks! I just used the mounting hardware that came with them and an M8x1.25 tap with the appropriate drill bit to mount them and since I lease my trucks I just vampire tapped them. No additional switches at this time. I'll have to look up who I bought them off of when I get home.
It's been a while since I snapped some good pics so I washed her, cleaned up the wheels and tires & of course she only stayed clean for a couple pictures...Damn the bugs we have here in NorCal.
  • Like 6
Just gave my truck her first real wash, and about to start slapping some collinite on. I'll try and get some good pictures tonight when I'm done. I can't wait to see my brownstone paint smothered in wax. I'm in love with this color.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
