First of all nice job. Secondly, does your pods come on only in reverse, or did you attach a switch so that you can turn them on individually? Could you provide a parts list that you used for mounting? Thanks
Sent from my SG Note 4 on Tapatalk
Should post a picture if you can of where you tapped into for power and stuff very nice
Sent from my SM-G900W8 using Tapatalk
I just tapped the harness right above where the lights are mounted so that they only come on in reverse or when you hit the unlock button at night.
The harness where the light pods are being mounted or...? Can you tell I'm not to mechanically inclined. [emoji6]
Basically there are two harnesses, one for each tail light. I tapped in the passenger side right where it passes over where I mounted the light pod and on the drivers side I tapped in right where the harness leaves the rear distribution block, again, right over where the light is mounted.
I finally installed my Airaid JR Kit with red filter, Truck can breath now and sounds great with Magnaflow
Good thing checked on M.I.T install today, had a full turn on Tube barb fittings and tightened all four clamps
so the additional lighting doesn't flood out the view of your camera on the screen when backing up? Also, do you have a website for the LEDs that you used, and I'd like to pick your brain as far as how you went about installing....Thanks
These are the exact lights that I purchased. You can find similar sets on ebay for a couple bucks less. I think I paid around $25 shipped.
http://www.ebay.com/itm/2X-6-3-inches-Off-Road-18W-CREE-LED-Fog-Lamp-Work-Light-Bar-SUV-4x4-Jeep-4WD-DRL-/171735291054?hash=item27fc3894ae
New mirrors in.
Did your towing mirrors come with the LED turn signal like the stock's and does it have the blind spot bubble mirror in it?. Mine has the blind spot mirror 15 Denali CCSB 5.3L.. Thanks
They do have the turn signals, but no bubble. I didn't know any tow mirrors had that. The spotter mirror serves that function pretty well though.
Could you possibly post a pic of your mirrors from the mirror side, and how do you like the look? Thanks man..
.... Also, were those tow mirrors made specifically for your truck, or is it universal to Chevys and GMCs
They are the HD mirrors, definitely not 110% PNP on trucks that don't come with them. Cant speak for the 15+ HDs but I know the early HD 15's even needed some changes in wiring or new wires to be run. If you get some you'll need to change wire harness or go the much easier and cheaper route, and just hardwire the 2 new components (white reverse lights and amber running lights) yourself. I did the second route when I got mine, much easier for me and cheaper.
The mirrors are made for the K2 body style. So you could put those exact mirrors on your truck, mine, or anyone else with a 14+ 1500 or 15+ 2500.
The bubble mirror you speak of is only a bubble cause its on a non-tow mirror. Tow mirrors have a much bigger version on both sides of the truck.
New mirrors in.
new mirrors look great man! Ive said it before and ill say it again, I love that green color, you guys make me want to start pulling every body panel and paint it that color on my truck!
Edited by Mike1220
Got my OEM built unbranded LMZ bulbs, works great and bright as f*** - no relay harness required confirmed!! and everything fits under the cap!
Played with the beam pattern a lot, this is the closest to stock I can get to with clean cutoff (I referenced the halogen bulb's offset)
Original Halogen bulb:
4500LM LED bulb:
I modified the direction of the wires to come out from the side and took off the back plate to add better air flow:
Yes, it does fit under the original dust cap, without the back plate removed, it runs hot, but you can still keep your fingers on the heatsink for 1-3 seconds before it gets a bit hot to touch, I think it is not that bad.
Running without any issues other than one light spot I cannot elimitate doesnt matter which direction I rotate them to. I can reproduce the pattern where it shows up 2 light spots with a curve up cutoff from motomedic or I get perfect cutoff with just 1 light spot.
No one has flashed me yet while running the 4500lm in my fogs too, I think it is actually brighter in my fogs..........
4500lm X 4 = 18000lm!!!!!! I dont think I need a light bar, I can see everything here in the boonies with zero street lights!
Edited by morrislee
Why should I get the HC when I can get the whole interior for $700 bucks instead of $10K?
I know this silly question applied to everything else like : why not get the Ltz or Denali and so on etc... No punt intended!
I got my fully loaded Ltz with every options that the HC don't have .Except for the red interior for $10k less
I was just lucky to have found the whole interior from a brand new wrecked truck for just $700 bucks. ;) would you do it? lol
So the sticker on your loaded ltz was 45k?
Where did you get these? What do you mean "OEM built"? I'm not aware of any manufacture that ships this kind of lighting from the factory on a new vehicle?
    1981dustin
    1981dustin
  • Who's Online   0 Members, 0 Anonymous, 1,635 Guests (See full list)
