Looks good man, I like those wheels allot. Shoulda done the black lettering though.
Man im in love I my issue with a murdered truck is getting the right light to show it off in a picture! And I like the white letter will give it a pop look :)
Sent from my SM-G900W8 using Tapatalk
Looks like a damn truck now! I shouldn't have waited
I had an audio shop wire my tow mirrors. But I have a problem.
The white LEDs work fine, but the clearance lamps only turn on if I manually turn on the parking lights or the headlights. They don't come on with the ambient light sensor. Does anyone know how to fix this?
Added 2" Spacers, pretty happy with the results, just need wider tires now.
Before
After
How but a side pic.
Sent from my SG Note 4 on Tapatalk
Before
After
Stud trimmming not required rigt?
only required if you have 1.5" spacers or less. Also only needed on 1.5" spacers if your rims do not have pockets on the back sides. Stock 20s have pockets
Said goodbye to the chrome honeycomb! Big thanks to member VTbulldog for his multiple photoshop version help and dla's photo posts in another thread.
How but a side pic.
Best I can do right now
No trimming sir.
Took the bull bar off.
Added a N-Fab multipoint bar, a 30" BlackOak LED bar, and a 20" Baja Designs Onx6 LED bar. Working on a custom mounting bracket for the 20" so it doesn't stick out so much.
Edited by Jlm02a3094
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
