Test fit some 20x12's. Absolutely in love with it..but it rubs..A LOT :tear:
Well simple solution to that...just don't turn lol
That's too bad tho...the x12's look awesome
I could forever drive in a straight line :D
Haha, I might just go with x10's. It's unfortunate but I can't remove certain chunks off the fender to make them fit.
I'll need to get more pictures tomorrow got these put on in the dark d9b93c3d2780fb75c64296184b0ddf62.jpg2d7173d8dbb1d874a0bee9f5b2c225a0.jpg619c00a2322ae83d696f6c49d58e2ce6.jpg344edb48a2edd2e095894c2fb82defef.jpg
Sent from my SM-G900W8 using Tapatalk
Today I felt what it's like to own a Tesla and experience range anxiety.
I planned my drive perfectly (fill up right on reserve) but that gas station wasn't operating, and the closest one was 20 minutes away (traffic). Ended up filling up 24.93 gallons.
Yikes! That was close
Sent from my iPhone 6+
Chad
How about a pic a little further back... What color is your vehicle? Thanks
Sent from my SG Note 4 on Tapatalk
It is silver I was in my garage when I took that pic here is a better one.
Chad
Was it previously color matched to your truck or black?
No wife no problem!
Looks good man, I like those wheels allot. Shoulda done the black lettering though.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
