How are you liking the Katzkin covers? How much were they? Worth it? They look great though
I don't like cloth seats so the katzkin's where a great up grade plus theyre made extremely well. For about $500 I'd say their definitely worth it ?? I highly recommend them if you're in the market for leather seat covers
Got jumped off. For some reason it decided the battery was low and wouldn't start... only been setting for about 20 min from the last drive...
I don't like cloth seats so the katzkin's where a great up grade plus theyre made extremely well. For about $500 I'd say their definitely worth it I highly recommend them if you're in the market for leather seat covers
Did you install seat heaters? If so, what fuse locations did you use? I have a regular cab, and both left and right "heated seat" fuses are in the drivers side panel. Strange decision.
Well battery is bad...great truck is only 14 months old and I bet its not covered under warranty......
I just did the covers no seat heaters
Installed ranch quick lifts. Front now sits at 39" and rear 39.5"
33" tires on stock 18" wheels
Installed a pair of black Anzo LED tail lights (Anzo part 311238) to replace factory kit.
Pretty simple install - i used this video and it worked well:
Keep in mind that the reverse lights and side marker lights are still analog bulbs so if you want to make it match you will need to buy a pair of 194's for the side marker lights and 921's for the reverse lights (FYI i tried with analog and it looked cheesy!). When installing the replacement reverse and marker lights, the connections are directional. Before remounting the lenses check the bulbs to see if they are on. If not just remove from their socket and rotate.
Total installation time (at my snail pace) was 30 minutes.
Edited by caveat71
Changed my cabin air filter, looks like the prior owner/dealer thought it was optional
Would think at the minimum it would be pro rated or pending dealer, covered.
Diped the headlight trim to see if I liked it in black.
This made me change my mind on the 6inch black running boards and go with the 4" tubular assist step...........
GM sport bar with aftermarket lights and GM fender flares
    Enduro73
    Enduro73
  • Who's Online   2 Members, 0 Anonymous, 1,530 Guests (See full list)
