Got jumped off. For some reason it decided the battery was low and wouldn't start... only been setting for about 20 min from the last drive...
How many miles are on it? Mine was the same at 32K. Battery was so dead it barely even gave a reading at Pepboys
Got 19k on it.. when not cranking it'll read 12v. Once you turn the key it goes to 7v or less. I charged it last night to see if I can make it through the weekend. Then off to ye ol dealer. Service manager claims it's covered
That's awesome!
When mine died the dealer said no shot [emoji849]
- Mike
IG: @BlackPearl_Edition
First nice day since I bought the truck last weekend and finally got her all washed up.
Edited by SStreet King
Looks great. Love the wheels!
GM sport bar with aftermarket lights and GM fender flares
More pictures from all angles and in bed?
Missed out on BedRug for $342 by like 20 minutes damnit.
Did get the GM branded one.
If anyone is interested in a bedrug for the 6'6" bed hit up member nbobinger, he has one new
Will arrive next week so hope to get it installed on the weekend
Took the truck to the dealer and they didn't have a battery for my truck in stock? WTF, seriously? OO well they gave me a loaner to drive and they happened to have 2 6.2L trucks...
Kinda thinking about switching to a 16? What y'all think?
Mine went dead about a month ago with ~66k. Still seems premature @ 2 years old...but there is a lot of electronics hooked up to these batteries. More of a pain to change too than any other vehicle I've ever seen.
I agree on the change being a PITA. 36K Or 3 years is supposed to be the norm to change batteries tho right?
Either way, mine have (2) 10" subs beating on it constantly. Also plenty of lights that don't always get turned off so my battery sees a lot of action.
Hoping my batteries from now on follow the same pattern. With any luck, I'll be getting a new battery for free every 2 years at pepboys:) lol. Got the 3 year renewing warranty.
I always thought it was 5 years, but as he said, maybe with cars having more electronics that the batteries just don't last as long anymore. At least not on the newer vehicles within the past 5 years. I can tell the battery will be more of a pain to change than my previous trucks, but can't be as bad as some cars. I know my mom used to have a '98 Dodge Stratus and you had to take the inner fender well out to change it. She's had an '06 Impala for awhile now and that's not too bad. You just have to move a support bar like theses new trucks and maneuver and twist the battery out.
I've always had good luck with Duralast batteries from Autozone. I was told that the Duralast Platinum battery is almost like a hybrid between a regular battery and an Optima so it's inbetween a normal battery and Optima. I'm brand loyal so I hate to even try another brand other than Duralast and of course everybody knows that Optima is great even though I haven't used one before.
Edited by SouthernSilveradoGuy85
See I don't have anything like that and I never drained it once.. It just decided to die. I think the dealer wanted me to come back so I would look at there 16s..It worked, I am seriously thinking of getting another truck and leaving this one....
Got it colormatched
attachicon.gifImageUploadedByTapatalk1462855385.038390.jpgattachicon.gifImageUploadedByTapatalk1462855399.043946.jpg
looks good
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
