Had a gear swap done today went from 3.42's to 4.10's. Happy with the feel so far, but still awaiting on tune update, and trying to take it easy on break-in
are the new gears Yukons? I'm interested in doing this when I lift my truck. Also, is this something the dealer can flash into the onboard computer or do we have to go aftermarket tuning only? thx
AAM. I believe the only way to update the computer is aftermarket as 4.10's are not a factory option on the 1500's.
Edited by SgtShiv
Added my step bar leds today. Tied them I to the dome lights so they come on anytime the dome lights are one. Works great with the key fob unlock and such.
Edited by mjdxtreme
That is definitely a cool mod.
When I added my hid's I had to shut the exterior lights off so I would not burn out the ballasts with the on off cycling of them. So figured after reading others on adding footwell lighting and assist lighting. Figured it would be the perfect mod for adding light while in dark parking lots and such. Works great and for like $70 bucks and an hour in my garage. They turned out great and put out tons of light.
Edited by mjdxtreme
Very nice... Would love to do that mod. Any chance you can provide a first time truck owner the write up on how to do this.? TIA
Sent from my SGS7
Sent from my SGS7
I cannot take credit for figure this mod out. There are several members who have done similar mods and I used the great info that they provided. Here is a link to where I got some of info to complete.
http://www.gm-trucks.com/forums/topic/172674-footfootwell-lighting-color-match-wiring/
This is just one place. There are several other links as well.
Thanks brother
Sent from my SGS7
Installed Pop & Lock and readjusted tonneau cover, wasn't quite right after bed liner install.
What lights did you use? Looks great!!
I cannot remember the brand. My brother found some on ebay. They were a set of two 5 ft long strip of led lights with a rubberized coating. 3m tapes to hold under the rockers. I can get a closer shot of them if you need me to. We ran the wires through the rubber grommet on the drivers side that the e brake cable goes through. And on the passenger side there is a plastic plug we drilled a small hole in then used silicone to ensure the hole was fully sealed. Snaked the wires under the carpet and behind the dash to the wiring harness that controls the dome lights.
Put her in a ditch over the weekend
bad weekend. are you ok ??
rdnckhntr94
Sorry that happened. Did you shear the bumper? Surprised it would break off like that.
Edit...I see now that the bumper bent and the cover lifted making it look broken off.
Edited by DAY11
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
