I did a thing with the suspension...
4" BDS and 35x12.5x20 toyo RTs with 1.5" spacers in the rear
Sent from my SM-G935V using Tapatalk
  • Like 4
Should change your forum handle to Mr.TxClean.
Sent from my SM-G930V using Tapatalk
Thanks buddy.... Very happy with the turnout.
Next is tint, amp research steps, and a tonneau cover.
5441e50ff4c8986329e633a057234c2e.jpgf3306051342efa470d9b5536f8fc98b0.jpg3d556e2e1a1625124719690e940db0bf.jpg2550f1f9b559c8dba66e5c6fd8ad5f75.jpg
Went to my buddy's place to install my 5100s up front and put my new shoes on. Looks great! Install was pretty simple. Slight rubbing nothing crazy
Did you set the fronts on the third notch?
Yes, max height. 295/70R17 nitto ridge grapplers
Very nice. Thank you.
Oh did that new purse just come in?
Ha! That's my laptop/work bag. Not something I carry around all the time. I'm not really a purse type of guy...
  • Like 3
haha I believe metro sexual men call them a murse! What other suspension goodies are you waiting on?
Looks great.
Sent from my SAMSUNG-SM-N910A using Tapatalk
And there you have it.... Someone always has jokes! lol
It's a satchel, Indiana Jones had one lol
Edited by Abearclaw
  • Like 5
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
