Finally finished the headlight upgrade project.
Went from LT - HID Headlights to LTZ - LED Headlights and color matched trim. Hopefully swap the bumper to color matched tomorrow.
Before:
After:
  • Like 7
Finished the replacing the led's in the back plus the resistor, plus a bit extra.
Looks good! Liking you marker plates too, fellow CT member
Sweet, you'll be loving the extra led with the switch back ! And mirrors folded in too ! Edited by Bmz72
Before:
After:
ddi you get any comparison shots between the HIDs and LEDs at night?
No. [emoji17]. I was too excited with the upgrade and had very little time from the moment I sold my HID lamps and when the LED lamps arrived. The transaction happened the same day on ebay. Didn't think about it until afterwards. It is definitely brighter.
how much did those led's set you back?
Out of pocket costs... $300 + $80 (to paint the bezel), + $85 for the lower filler panel that the new lights didn't come with... so $465 ish.
Sold my stock lights on ebay and bought the take off lights on ebay - the same day.
Edited by pgamboa
roundsy can you tell where you got the lift from, i am in the alliston area
I called FTS and ordered direct.
Damn, that's not too bad of a net price.
Yup. So my quest at getting to an LTZ Trim Level so far, is about $1300. Between LTZ Tail Lights, Head Lights, DL3 Mirrors, Auto Dim Rear View, and Heated Steering Wheel. Not bad when you compare the Trim level price difference of about $8K or so.
Mounted light bar and switch. Have not wired it up yet. f24c494860360549e7576b068f6624a2.jpg581db5b40801eae60528cc753b148a80.jpgc82ca2f06eba59e043d4369373abc921.jpg
looks good
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
