Added 1 coat of vht night shades to the turn signals. Haven't touched the can in years I forgot how dark it is. Not the look I was going for so ill have to get it off tomorrow. Way to dark
Match the headlights and fogs and I bet it would badass!
Did you end up redoing it?
Let me know what route you end up going.
Waiting a couple days to do fogs and see the look
check out Lamin-x.com - I used there lite tint on my fogs , I happy with it.
Can you post a photo for visual?
please enlighten me, what is this ceramic coating you speak of?
Here is a good explanation of what ceramic coating is: http://exclusivedetail.com/ceramic-coatings/ If you decide it's for you, make sure you have them do a paint correction prior to applying the ceramic coating as that'll make it look all that much better and you're starting with a consistent base.
Change out my transfer case fluid. Easy enough to do, but had a mishap with the funnel. Good thing I placed cardboard down on my garage floor. Was going to do the rear diff too until I realized I got the wrong oil for it.
Was that the transfer case drain plug on your 2016??
Sent from my E6810 using Tapatalk
Yep. 34k miles
Holy cow man. That's crazy! Normal use of the four wheel drive? Any extended drive time in auto?
I would be taking that component apart and making sure that everything was/is good. May want to even flush/clean it out, make sure all debris is removed. Any chunks amongst all those shavings?
Nope all extremely fine shavings. Haven’t noticed any issues and the slight whine noise under acceleration in 4wd present since the truck was new has subsided over time. Or I just can’t hear it over my tires anymore.
Normal use. I usually use auto when I need 4wd just to preserve my turning radius and decrease wear. Only use 4hi when in deep snow or on logging roads. 4lo as needed to pull the occasional bush/rock or tow someone out of a snowdrift.
I had really nice looking Blazer that I bought used. Many months after buying it I finally did a thorough check if all components and found the transfer case bone dry. Filled it up and never had a leak so I'm guessing someone did a fluid change and forgot to fill it. Never had a issue after that. I think they're pretty tough but yours certainly shows premature wear.
I didn't need anything when I changed the back up and third brake lights to LED.
Sent from my SAMSUNG-SM-N920A using Tapatalk
You having any problems with a leaky 3rd break light?
Sent from my Pixel XL using Tapatalk
No I don't. I made sure to put the third brake light nice and secure.
New wheels!
18" method grids in titanium. +18 offset.
Next steps are bigger tires and to get rid of some chrome. Maybe some nfab steps?
I installed a Volant CAI on my 2017. Took about an hour. It seemed to feel stronger. The intake noise is much nicer than the stock unit.
    1981dustin
    1981dustin
  • Who's Online   1 Member, 0 Anonymous, 1,564 Guests (See full list)
