New wheels and tires 295/70/17
looks good - does it fit in your garage or parking ramps that are 6' 8" ???
Road trip up Mt Washington , White Mountains, NH. What a view from up there!!
what rims are those
Here's a couple night pictures. I'll try to get another tonight away from all other lights. 09e101a9598b91880929ce622ef2de52.jpge1c33f6c6529d1efb16c0c952bdf35ca.jpg79ec98b1545b00e8530caa417f96b57d.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
Can you see with the backup camera at night or does it all wash out?
Lol. Lol. I thought the same thing when I looked at the pic. Lol
Sent from my SM-N920V using Tapatalk
Is that a RC 2.5 lift?
What little I've used em it seems to be ok with the back up camera. The lights are a combination between spot and flood. I've got them pointed down quiet a bit. I can't get a picture here in a little bit and post it.
I have a similar setup and I do not have an issue with backup lights drowning out the camera at night.
Sent from my Pixel XL using Tapatalk
I took mine out to check it. Found the darkest place I could. My lights are angled down more than my previous set up. No issue with mine either. d55bd4025be24a8bcd3d1632e401dc51.jpg
Not something I did but what the wife did... Caught her sprinting out the door with my keys to make the coffee run.005350b566fa7270a303a14913e55c9b.jpg
I had some led reverse lights on my old truck and it completely washed out the camera at night. It was aftermarket though. Just curious with the oem one. Thanks.
I just put new lights on. They are even brighter than my last ones. I'll post a night pic tonight.
Got my truck leveled the other day by 4 wheel parts. Had them in stall a 2.25" Trail master level. Hoping to have wheels and tires here real soon!397c1b94b4dfa4ae74ca959f182cad70.jpg
Sent from my SM-G955U using Tapatalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
