Just clips. The door and vent trim is stupid easy.  The stereo shroud is a bit of a pain though even though its just clips.  Even with my trim tools It felt like it was going to snap before coming off.  There are 2 screws you can take off the back of the vent shrouds to remove the little window diffusers.  Drivers side vent shroud is exactly the same except it has 3 wiring harness's with lots of slack that can easily be undone after pulling it out.
Quick vid showing how stupid easy the other trims are.
Got carried away again and used another few yards of vinyl.  Started with the steering wheel trim (I was debating leaving the piece where the stereo steering wheel controls would go but it looked odd so I decided to cut it out)
That went so smooth I carried on and did the door pockets. (never knew there was a light in there...)
Again, everything went swimminly so I carried on and did the glove box latches. (I'm Not sure I like them but it got me thinking it might look good with the both glove box doors done and the center piece of the upper dash but that's for another day)
Things went to smooth so decided to punish myself and do the console and cup holder surround.  (It was by far the hardest piece I've done.  Not to mention I used one solid piece with no inlays to do it.)
Was thinking I might tackle the upper part of the outside mirrors and the door handles since mine are just black plastic anyway but again for another day.
Well that looks easy. I was going to leave them on but didn’t really want to slip and cut the leather or plastic. Definitely just going to pull them. Now to decide which color to do.
I did most of my trim pieces and was thinking of doing the console parts as well. Does the trim around the cup holders come off or did you do it on the truck. Everything looks really good by the way. Thought about doing the glovebox latches as well. Mine might look weird though since it’s Realtree camo. Lol
Delivered via my cellular device using a mobile chat forum thingy.
Everything I did today I did wrapped in place.  I know the upper console comes apart fairly easy as If i recall from the thread about guys retrofitting the wireless charging into it but I there not much to gain by removing it from the truck.  I believe the cupholder trim can come apart but I believe its quite involved so I just opted to do it in-situ.  Took a very big piece of vinyl to make that relatively small surface area.
I'm quite impressed with this vinyl I got its actually for exteriors and is really thick compared to others I've worked with.
Still doesn't even look like I've touched the roll I guess 1.75x60M was too much =p.
@Crazyjoker77 That looks amazing! Where did you buy the vinyl? I've got a kryptek theme going on inside my truck so I'm trying to find a place that prints that on 3M but the scale is hard to find.
On 6/23/2018 at 9:59 AM, STINSAN3 said:
Got my new wheels and tires put on!2d103c8068fb0d0952140b7323601b11.heic1277db037e13e656f02bba6427c05037.heic2992315c09531c0b80d2e755fee4bc99.heicdba4976b7d4cee7d8ec5c75fbec7ce9a.heic
Specs on the wheels?
Just happened today while raining. The truck lights turn on while the truck is off (happened at first key in ignition but not on, and then again while unlocked key not near truck). All of the lights turn on and the turn signals flash. It goes for like 15 seconds or so and then stops. Has anyone had this issue yet?
I took 2 things I would say were useless to me and made them useful
Never left this unlocked so can’t use the USB, and never used this storage for anything more then safety glasses.
Will work tell apples new update and I’ll have to replace the cord for the 100th time.
1d047f7520c34eac44d5181eb262ee3c.pnga2663e56d336b219ec351dc05d207672.heic picked up the truck from getting the new 7-9 McGaughys suspension put on and cognito upper control arms. Rides so much better and the angles are perfect! Selling my 7.5 RC lift if anybody wants it
  • Like 3
I've seen some guys use that USB for their phone holder, on the left side of the steering wheel, in the pocket/cubby, if you don't have factory installed trailer brake controller.
Edited by Ravenkeeper
ANY problem with Green grill lights ??
    MASONV88888888
    MASONV88888888
  • Who's Online   2 Members, 0 Anonymous, 1,622 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
