Hey all, I am having problems with my brand new silverado starting. The this in 4 days old just rolled it off the lot and this is what is happening to me. The past 2 mornings and last night when I was getting ready to leave for work. I went out to start the truck and all I get is a single click when I turn the key in the ignition. Try it again a few more times and the same thing has happened. I quit for 5-10 minutes after trying and go back out and try it again. It fires up first try with no problem. This morning I attempted to see if it was a battery problem and tried to jump it with no success. Wasn't sure if it was a loose contact so I wiggled the steering wheel and shifter and still no results. Brought it into my local chevy dealership this morning after having the same issue and finally was able to get it started. They hooked it up to their computers and checked it all and said their was no errors reading. They told me they were going to contact GM via their help portal and still have yet to hear anything. I was wondering if anyone else is having the same issue. I also posted a video this morning to Youtube showing what happens when I first try.
this is obviously only a short term solution but have you tried starting it remotely and then putting the key in?
We just bought a 2014 silverado last Wednesday. It wouldn't start on Saturday. We jumped it brought it in and they said there was nothing wrong with it. We brought it home again went to start it in the morning and its dead again. We towed it to the dealership where they can not find anything wrong with it. The truck has 180 miles on it. Which have basicly been used up driving to the dealership and bringing it home from the dealership. The dealership is 50 miles from our home.
I read on here somewhere that some trucks had a problem with the starter solenoid not making contact because of too much grease or something around the contacts in it. The solenoid pulls in but the engine doesn't crank over.
I believe one of the BCM updates addresses this very issue. Separately, I discovered one of the terminals on my battery was not totally tight on mine, which caused weird electrical problems that went away once the terminal was tightened.
The batteries that come on the 14s are pretty pathetic if you ask me. I live in Canada and we have had quite a few -30 and lower days now and I have had to use my booster box a lot now. I went into the dealer yesterday about this and they said they know the factory batteries suck as a few people have complained to them. I've also noticed the truck turns over for ever before it will catch when it's cold out which drives me nuts. Hopefully GM will give us an update for the cold start start problems.
Exact same problem here. Had the truck 5 days now. Either with remote, onstar, or key it seems to have a mind of its own. Same thing when I took it to the dealer yesterday.
Update on my situation. Leaving the truck at the dealership overnight so they can run a test on it in the AM. Will update when I get called tomorrow.
I plan to make use of that extra battery tray.... I wonder if that would solve your problems?
What is the cranking capacity of the OEM battery? This whole thing stinks. I have never, ever had any starting issue with my truck and it is 8 years old.
I'm anxious to hear what the dealer experiences and what they have to say.
giloma - when yours wouldn't start, did it even crank? If not, the jump start might not have really been needed. As with my issues, you try to start it and it just clicks (no starter activity), wait a bit and try again and it fires right up. The batt is strong. It may have been a result of the timing rather than the jump starter. OR... you had a low battery :dunno:
    ncleg
    ncleg
  • Who's Online   5 Members, 1 Anonymous, 792 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
