I'm just curious. How many miles are on these tucks with the starting problems?
First time was last Friday and it had 25 miles. Second time was this morning and it had 83 miles.
Mine started the morning after I bought the truck with about 50 miles on it.
***maybe I should rephrase that***
Mine started ACTING UP the next morning after.
Edited by chelmer
So the next occurrence is expected at roughly 140 miles?
I am assuming the next time is below zero if this starter didn't fix the issue.
Picked up my 2014 Sierra Feb. 5 - was built Sept 2013 ..........I has not started on any day that I have owned it .......... I can fiddle with it, remote, in cab, lock, unlock and after many tries will start. Dealer removed starter and heated inside and reinstalled on my truck the next day ...........took it home and it would not start the next day. After 26 attempts to start today it started by remote on the 27th. Took to dealer after showing him this thread and he replaced the starter. We will see tomorrow morning. The Service Manger was being told by GM field engineers to NOT just replace the starter - try the bake out procedure. Well, I looked at the bad starter and all seals were intact as best I could tell. Valero may have assembled the starter in 80% relative humidity and 80 deg. F, which would lead to condensing moisture in the solenoid portion of the starter ........I can not see how the "baking" process would drive out condensing humidity. GM wants to handle owners on a case by case basis - I disagree and GM should issue a TSB as soon as GM and Valero bracket the offending production dates of the starters and trucks. 2013 Trucks have the same part number starter and have not had this problem that I know of .......... They will get to the bottom of this .........meantime, us cold weather frustrated owners and some good dealers are struggling with this problem ..........will post a start or no start tomorrow with a NEW starter ...........should be 10 deg. F or so ......
I do really like my truck, but it really should start for me to keep liking it ..........good thing I have other vehicles available.
Cut that stupid flapper out of the exhaust and call it a day. Now mine just doesn't like starting when it's been sitting for more than 5 hours in the cold. Making progress!
Add me to the list. Purchased 2014 Silverado Double Cab Z71 on a Wednesday. I live in Wisconsin. Temps have been -20 to 5 in the mornings. Friday truck wouldn't start. Towed back to dealer. They said battery had low charge so they charged it up and gave it back to me later that day. I wasn't convinced because the tow truck driver tried to jump start the truck with no luck. Saturday morning wouldn't start. Towed 2nd time to dealer. This time I was told battery failed testing. Replaced battery Monday and kept the vehicle until Wednesday. They said everything tested good for 2 days. I received the truck back on Wednesday. All good until Saturday afternoon. Towed a third time. They thought the truck had some sort of power draw. Dealer called me Monday and told me GM engineers were sending them a new starter to try. Starter was suppose to arrive today but it didn't come in. Will be delivered Thursday and installed. I will let you know if this fixes my truck.
well guys still no fix, my 2014 silverado was towed in for the 2nd time in 6 days
my service dept tech found one of the battery grounds going to the frame had undercoat under the cable, cleaned that off & it started right up. drove it home,
the next morning well you guessed it, no start no crank. the gm smart guys gave us a part # for a completly different starter,i should have this part by friday. if this works i will post the pt# for this new & improved starter. kinda bad when you work for a chevy dealer & your new truck keeps being towed to work every day !
At least you get a ride to work every day. I get stranded in the middle of nowhere when mine wont start haha
At least when you get yours started you can drive it. Several times now mine starts but drive does not engage. Have to run through the gears 3-4 times before it will grab and go.
LOL..... i still dont have a loaner truck, & i work for the dealer ! wait till they get my how was your
experiance card back ! they sold my trade in in 2 days so i cant drive that.
March of 13' I replaced battery on my 97' GMC down at Sears Auto Center in Florida. I've used Die Hard batteries forever the past 10 years while living in Florida and was able to get about 3 years out of them before they crapped out. The heat, etc. really takes it's toll on batteries in this region of the country.
I told the guy at Sears I was moving up to Chicago in a few weeks and he stated....."oh boy, this new battery is not going to last you very long". He explained that in warmer climates, the sulfuric acid/water solution is different depending on what regions of the country you live in. In warmer climates the solution is weaker so the battery does not get too hot internally. Likewise, when you purchase a battery in regions of the country where it's much colder, the solution is stronger as this allows for maximum CCA and since it's so cold, internal heat build up is not a major factor.
I can assume there is some truth to this. Just wondering if GM is installing the correct battery based on region of the country these trucks are being shipped to.
I've thought about replacing my battery, but I think that is GM's job, not mine. I haven't looked at the battery to see what the CCA are, but it cranks fine anyway, it just doesn't like starting.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 581 Guests (See full list)
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
