AC whistle sound?
Hey guys! Im having issues with my AC... when im driving 50+ mph and have the AC recirculating button on... i here a whistle sound and when i turn off the recirculating button off the sound goes away. Does anyone know what it might be? Or have any of you had that issue before?. It's CC 2WD LTZ silverado if that helps.
My 2011 Sierra has a motor noise that almost sounds like a chirpy whistle. Only does it when its in auto mode and kinda mid range speed.
I messed with all the buttons and I narrow it down to when the air is recirculating. Im wondering if the gates are not closing all the way? It only does it when im going at 50+ mph if i go below speed i wont hear the whistle noise. My silverado is 2014.
Took it to the dealer and tech said they couldnt replicate the sound. Took the tech for a test drive i heard the whistle along with another guy that works at the dealer he heard it too but the tech said he couldnt. He said he can take the dash apart and look in there and see if anything is wrong but he recommended not too. They said they will call GM and see if they have any issues with that or what they recommend to do.
There is a whole thread on recirculating door apparently not closing all the way and causing fumes and other road smells to enter the vehicle. It seems that "whistling" would be the sound of air outside moving past a partially closed recirculating door. Another great redesign by GM. They cannot leave what works alone.
I found the thread you are talking about and im going back to my dealership and see if they can close it all the way instead of 90%. Hopefully that will fix it.
The recirculate door does not close all the way so that you always have a constant positive pressure of fresh outside air. Otherwise you would suffocate from lack of oxygen, in theory. I dont know that the trucks are that sealed, but thats why.
Sent from my LGL86C using Tapatalk
  • 2 years later...
U sure you don't have a dash vent closed? Mine sounded like a jet engine, then I realized my kids closed off the passenger side vents.
I have the same issue and cant figure it out. Will have to check this and see. Truck is in the dealership now getting work done and have a 2016 suburban as a loaner and have the same issue.
do you have the link to the thread referenced above?
I had this exact issue...I thought my filter was clogged...turned out to be a almost fully closed vent on pass side. Never crossed my mind until I went looking to change the vent filter....lol. Very noticeable whistle sound.
  • 2 years later...
Did you guys ever figure this out? My 2019 is doing this exact thing....
