This thread made me curious, so I crawled under my truck today and checked out the coating. I couldn't find a single area where the coating was flaking or coming off, or appeared to be damaged at all. Only a couple bolts on the leaf springs were slightly rusty. In all fairness, my truck had only seem Texas rain, and sand/salt/snow a few times over the winter. I've owned it since last July. Silverado LT Crew Cab Z71 4x4 with a build date of 5/13.
Dealer just put a 6 inch lift on a lot silverado crew. The edges of the front suspension and rear well wheel edges we're rust coloured. Looked like azz
Unless you can see it without crawling under the truck, I fail to see an issue. I raise GM trucks of all ages everyday. They all have rust on the frames, differentials, drive shafts etc. Never seen one rust through and I'm in salt country. To me its just cosmetic.
Edited by tbarn
The wax coating is sold by GM parts under part number 12346501. It is an excellent match to the OEM applied stuff.
took my moms truck in today to have them look at this issue was told that it was normal but they will fix it my truck is also having the same issue
heres pics of my 2014 crew cab 5000 miles next 2 pics are of my moms 2013 crew cab only 6000 miles and the last two are my brother 2012 ext cab with 13000 miles his looks almost brand new besides the one spot on the driver side
4f2329e4-a65c-471b-a0c0-75b62e5e7aef_zps526cd867-6715-48a9-a339-155303f40e90_zpsd73cdad8-1a91-4059-a24a-4333389e4307_zpsed1a9b9c-982d-45ce-9665-6d11a1dc3643_zpsb8f5d7db-cc69-4bee-8bfc-2493baf67a0a_zps
after reading this post i checked the frame rails on my 5000 mile 2014 standard cab 4x4 silverado work truck. yes, i have rust spots where the wax is peeling off. looks terrible and i doubt the frame outlives the truck. but what really has me worried are the emergency brake cables rubbing on a frame clip. obviously GM knows about it because my truck has rubber sleeves over the cables where they rub the clip. you'd think they'd move the clip, re-route the cables or hey, better yet, move the wire hanger they installed about 6-8 inches aft of the clip. i am thinking that is what i am going to do. gm - fail. i have a couple gallons of LPS and i will foam brush some of it on the rust. who ever thought up this wax stuff needs his head examined.
GM in general needs their head examined. I have 19k miles. Mine are not spots, they are sections. It's pretty bad to say the least for a 9 month old truck. Probably the worst on this forum due to an early owner and in a winter / salt area.
I wish I would have kept my avalanche... Just frustrating dealing with piss poor products at the price these things go for.
Sent from my iPad using Tapatalk HD
Edited by Trackermi
question for GM, will this wax undercoat ever set up or dry? if not, is there anything that can be done to it, sprayed on/over it to seal it? i read on a previous post GM is clear coating the wax undercoat on some models. any chance i could have my truck done too?
There is a "bullitin" at the dealers for the fix. Mine is going in today 5/19/14, to be fixed.
do you know what the bulletin from the dealership addresses? is it to "fix" the rust areas or overcoat the forever sticky wax undercoating?
can anyone share their DIY repair/cover ideas/solutions? thanks in advance.
threre is 2
#PI0564D: Wax Coating on Frame Peeling, Metal Shows Corrosion/Rusting
- (Sep 5, 2013)
Subject: Wax Coating on Frame Peeling, Metal Shows Corrosion/Rusting
Models: 2011-2014 Cadillac Escalade Models
2011-2014 Chevrolet Avalanche, Express, Silverado (All Series), Suburban, Tahoe
2011-2014 GMC Savana, Sierra (All Series), Yukon, Yukon XL
#14002A: Service Update for Inventory and Customer
Vehicles - Underbody Appearance - Expires with Base
Warranty - (Feb 10, 2014)
Subject: 14002A – Service Update for Inventory and Customer Vehicles —
Underbody Appearance – Expires with Base Warranty
Models: 2014 Chevrolet Silverado 1500
2014 GMC Sierra 1500
This bulletin has been revised to increase the allowable per vehicle “Net Item” amount for
the Daubert Nox-Rust® and Lloyds Kryptonite Metal Treatment®.
This service update includes vehicles in dealer inventory and customer vehicles that return to
the dealership for any reason. This bulletin will expire at the end of the involved vehicle's
New Vehicle Limited Warranty period.
Purpose
This bulletin provides a service procedure to inspect and, if necessary, repair the appearance of
underbody components on certain 2014 model year Chevrolet Silverado 1500 and GMC Sierra
1500 vehicles that may not meet GM appearance requirements for new vehicles. These vehicles
may exhibit signs of premature surface degradation on certain underbody components.
I had a couple of spots that were beginning to peel on my truck. I removed the loose wax, fully cleaned the areas, and applied the same stuff, but in an areosol can, GM part number 12346501. It was an almost perfect match.
Yep, I am going to have to take my truck in for this repair. I take it will take 2-3 days to complete. Add paint repair to the insider driver's door that bubbled up and is exposing the primer. Guess I will be driving a rental for about a week. The sad thing is that I have to drive 160 miles to get this repaired. The good news is that I will be in a city where the repairs can be done for a couple of weeks. The scary part is that they have to remove the bed and other parts in order to make this repair.
    RichardRS
    RichardRS
  • Who's Online   2 Members, 0 Anonymous, 753 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
