Okay. Pick out some wheels for my truck. I've looked at so many I don't know what to do
Everyone is doing black wheels these days. I'm an old guy and have always done chrome. So I'm down to either Hostile switchblade in chrome or Hostile sprocket in black and machined. Someone please make the choice. I'm tired of thinking about it.
Edited by Bigfoot16
Flip a coin
Long time lurker, first time poster.
Looking to upgrade my 18" OEM's with 22" SEY's. I'm really focused on how the tire will look when its mounted. There's a certain look I like, and a certain look I don't like. I don't like how the factory tire looks. I've seen someone post some pages ago that had the Cooper Zeon LTZ's. That is the tire I'm looking for. I believe they were listed in the pic as being a 305/40/22. I think I'm going to stick with a 285/45, however when I look at Cooper's website I don't see that they make the Zeon LTZ's in a 22. I'm hoping that someone will say "you didn't look at the right spot, they make them and here they are", hence the reason for my post.
Anyone have any insight maybe or if not, maybe a mfg. that has a very similar style to the Zeon LTZ. Thanks!
EDIT: So some internet searching and I found them available in the 305/40/22. Issue I would see is they recommend a 10" rim width and the OEM's only come in a 9" that I've been able to find.
WELCOME.
Let's see a picture of your truck and the two wheels you have in mind
Sent from my Nexus 6 using Tapatalk
These are the two he's looking at. I also was considering the Switchblade. I was starting to think I was the only guy here who preferred chrome.
Edited by Doug64
I'm considering these Denali 20" now since they're cheaper than after market and chrome.
IMG 4130
IMG 0191
IMG 2219
2015 Silverado 2 1/2" RC leveling kit, 20x10 -24 Fuel Mavericks on 33x12.50r20 Toyo Open Country R/T's.
Barely rubs the plastic on the back side of the fender, minor trimming will do the trick.
Edited by SilverBullet83
I'm having a hard time believing those are 275/65/20's, they sure don't look like a 34in tire
this shld shed some light on it
Thanks guys. I'm actually considering the black and machined Hostile sprockets. The chrome switchblade is really nice. Thanks for putting that picture up. I'll post a picture of the sprocket shortly
attachicon.gif18642-12-2007-f-150-ford-leveling-kit-hostile-switch-blade-chrome-slightly-aggressive.jpg
Thanks for posting the picture. I'm an old guy... so I guess thats why I've always been partial to chrome. But since my truck has the black front end I'm not sure which way to go. When I was a kid, if you had black wheels it was because you could not afford hubcaps.. or somebody stole them
I like it. How do you like the R/t"s? That is the tire I ordered
