Get them mounted today.
Replica 22" CK158
305/45R22 Nitto Terra Grappler G2's
ReadyLift 2.25" Front Level
No rubbing that I've noticed so far. Full lock in reverse could pose an issue as its really close, so I might just go ahead and tie back the liners just in case. Really liking the look of it.
Sharp truck!
Fab tech 2" level
Original 20" All Terrain wheels polished and painted Iridium metallic to match the truck.
Michelin 285/55/20
Got these on today
Hostile black and machined Sprocket 20x10
Toyo Open Country R\T 33x12.50
Got these on today
Looks great! What lift/level and what offset are the wheels?
That is one hell of a nice ride... I have a 2016 White Z71 LT ordered. Love the 2016 Silverados. How much rub with that setup
Got these on today
attachicon.gifIMG_0968.JP
Got these on today
Thanks.. I have no rubbing at all with this setup
Looks killer. How much cutting or rubbing is involved here?
Thanks.. I've always been a chrome guy.. this was a big stretch for me.. I didn't have to cut or trim anything...
22" PVD Chrome CK156 SEY on 305/45-22 (33") Hankook Dynapro ATMs
2" level, zero rubbing
Edited by dbcooper
Level 8 Mk6 in gunmetal, 18x9 0 offset
BFG K02, 305/65-18
4" Fabtech lift/level
Slight rub only at extreme left/right wheel turn.
Lightly trimmed the front Husky mud flaps near the mounting screw holes.
F1F9CE11-2FF2-4EF8-BFEE-3A10C71502E0_zps
E3AAB9BB-D670-49C8-B176-53E9AAB6671B_zps
AA0A4C89-5E7A-4B55-A422-6838132334C9_zps
997511E9-B1B0-454B-A37A-9C718ACE2A1F_zps
0315252A-E7E8-489E-8BF2-DE2E42EED0D4_zps
8AF89CD8-4756-41EA-9260-86E8421D7E03_zps
D1052A8C-9B04-40E7-8DBD-80B1CA1AEBEE_zps
A383D59D-5E2F-4805-83C8-08269E142186_zps
A8948F99-FF9E-47D2-A76C-39D84B8C9F88_zps
12E04F9F-95FA-4871-96F3-BD1B02C4C9FB_zps
1A45D266-39F1-46CB-96DA-1216ACF4DAC1_zps
1293CC89-32AA-4A5A-8D42-4C873277DED3_zps
7145A028-BD82-48D2-A1E5-6D368BA9AB22_zps
E179AB95-B835-4366-9144-1EC1A7E5E6F6_zps
E8FE7F01-255D-4EF5-A757-2232D18F5F5A_zps
189B6654-3CE5-4ADF-8C2D-D7D6AA457269_zps
62893C0E-F7E1-47B5-A076-F42B2FEF4269_zps
1D1C4C08-9E55-4C57-98ED-FE9233E82DEB_zps
CDE8F505-3DA0-4CC5-978B-8145E0EBF846_zps
Front top of fender well height
04D3B362-7B91-4A4D-B5D1-D827E545A86C_zps
Rear top of fender well height
A25D4B8D-1886-41F0-ADFB-DF0EC9503026_zps
Meethod Mesh 17x8.5, 0 offset,
285/70/17 BFG T/A KO2,
2" Level
That looks perfect, did you correct speedo? Looks like it wouldnt be far off. No rubbing right and looks like they are just inside or even with fender?
I didn't bother to correct the Speedo, it shouldn't be too far off, no rubbing at all and they stick out about 1/2" past the fender.
What's the lift on this, looks perfect
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
