Looks really good! Those are standards right? Thinking about those polished for mine in 17 with 33's. Whats the lift and wheel/tire specs? What did you do to fit them?
Yep, Method Standards 17X8.5 with 35x12.50 Toyo AT2 Xtreme (They accidentally ordered these and I didn't notice until it was too late so didn't even both to go back, just stuck with them). I wanted the regular AT2. These are kind of loud for my taste, but I have never had a big tire setup like this so I wasn't expecting it to be dead silent either.
As for lift, I went cheap because i'm 2wd. Running Maxtrac 4.5 lift spindles on top of the RC 2.5 level/lift I had in there and a 4" lift block in the back which will be changed out for a 5" lift block. Blistein 5100's are in the near future but I ordered a Diablo i2 last night for under $300 so I jumped on it quick. Hoping to get some MPG back.
4 wheel parts currently has the Blistein 5100 set at $300 flat so hopefully buy them friday.
As for fitment, just had to cut a slight angle on that front plastic under the bumper which is getting removed anyways . Otherwise,fit like a charm.
I did find a bunch of issues while doing the lift though, like a bad tie rod, both rear shocks blown, warped rotors (measured with micrometer). Going aftermarket on rotors and shocks because OEM is garbage.
Do you have a link the 4 wheelparts I went to didn't even offer Bilstein?
Found it had to look under 2015 tried 2016 first.
Blistein 5100
Just picked the truck up from alignment and the thrust angle is WAY off. Anyone that may have some insight, please check out my thread started in the troubleshooting subforum. Has printouts as well.
Your truck looks great. However, don't be too upset with your tire shop.....35" AT2's are only available in the XT version.
33x12.5x22 Toyo M/T. Stock chevy 22's with a 2.5 RC level
  • Like 3
Any rubbing issues?
Oh, didn't know this! Good to know, thanks Big Whiskey. I'm already use to the tire noise. Getting them road forced balanced today because the wheels already kicked off a few weights AND there are weights stacked on top of each other. Really poor job.
Any rubbing issues?
Nope. No rubbing at all. Just have to get use to the little bit of extra road noise.
Yeah, aftermarket rims are great for chucking wheel weights, haha. And, you're probably limited to clip on weights on the inside lip, and stick on weights as close to the outside as they can get. If it's the stick-on weights you're chucking, try putting black duck tape or gorilla tape over them. I've had good luck with that over the years.
bfg k02 275/65r20 2.5" rc level26642116184_eb8598f5e8_h.jpg
hey, how have you liked these? Do you have any rubbing? This is one of the larger diameter tires I've seen on a non-lifted 1500 series truck.
I have a 2" level kit on my Silverado and have a liking to those size of tire.
Bilstein 5100s on front and back (front adjusted for max height at ~2"), Readylift 3.5" block replaced factory block for added 1" in rear, Nitto TerraGrappler 275/70R18s on Mayhem Warrior 18x9 +18 offset wheels. No rubbing.
Went with XD Series Crank wheels, 18x9 0-offset........BFG KO2 275-70
Debating on 2" leveling kit or bilstein shocks to get closer to level......what does everyone prefer?
  • Like 3
I like the $50 2" level kit. But that's just me
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
