Bumpershellz looking good!!!!!
Thanks man they’re holding up really well thanks for gettin that group buy going
Glad to hear, mine are holding up great too!!
I wasn’t sure how good of an investment it was at first so I only got the front but I’ll be getting the rear eventually lol
305/60R18 Mickey Thompson Baja ATZ P3 on stockers.  Used to have same size Cooper ST Maxx on Fuel Anza.  Old tires went 60,000 miles and the wheels looked ratty/pitted.  So, I went with essentially the same tire and found some take-off wheels.  Cooper owns M/T and Cepek tires and makes them based on the Cooper line, but with some small tread differences.
Edited by Spurshot
I have a 2015 GMC Sierra SLT with a Rough Country 2" Leveling kit. I have 20x10-25 wheels and 32x11 Toyo Open Country A/T. No rubbing whatsoever.
2014 Sierra SLE on stock wheels with a new set of Copper Discoverer AT3s in 275/65R18. And no air dam.
Edited by HeyCoach
740B3B16-C248-4666-A50B-4B6F4BCF4D24.thumb.jpeg.d9927c0d25d2fa9631a2fa7d627f2995.jpegNew to the site just getting started 275/70/17 no lift no rubbing at all. Love how it fills out the space BFs
Edited by Jbridge11
Trying to figure how to rotate pic
Readylift 2.25" strut spacers and tubular upper control arms swap. Stock rear with stock 285-45/R22 Bridgestones (for now).
Love the new stance and the ride is great.
I had intended to use another company's relocation brackets for the magneride (Readylift doesn't make one) however after installation, the thicker tubular UCA but the sensors right back in the stock position. No relocation bracket needed.  I couldn't be happier with the setup. 5b2fb12848b38abfb6f438935a3a6ab7.jpgcd39b395887b7a8f9da89a00cdc1ec31.jpg
Sent from my BBB100-1 using Tapatalk
Edited by Avolution03
Chevyryda254 did you smoke your own tail lights? I want to black more of my truck out looking for easy replacements that don’t require much modding and also want to black out housing in headlights or buy some... so many options was hoping to get insight from people on this site
Jbridge11 my taillights are just covers I bought off of amazon they weren’t very expensive
They look great
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,276 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
