2.5" RC Leveling Kit and 275/65R20 Goodyear Duratracs. The tires rubbed just slightly on the fender liner, a couple zip ties solved that. Thx Mr. Drag Sledder for the tips.
  • Like 8
2.25 Ready Lift with 295/55-20 Nitto Trail Grapplers
What is the wheel offset? Do the tires/wheels stick out at all? Any rub anywhere?
20x9 with +18mm offset - don't stick out and no rubbing
Now that looks right..nice truck.
I wanted to make sure everyone got my setup on here as well.
2 1/2 RC level kit w/ 2" spacer in the rear, 295/55/20 Toyo AT2 Xtreme w/ 14' All-Terrain stock rims on my Denali. The front's rub a little, looking at adding .25 inch spacers in the front. Has anyone done this, will it stop the rubbing? I sent an email to RC and they said that "should" work but obviously would like to talk to someone that has attempted it. The offset is supposedly a +34 for the stock AT's so that looks to be the problem not the tires. Do you need to put spacers on all 4 tires to make sure they ride the same for alighment/tire wear....etc?
  • Like 4
Looks GREAT!!!
Just thought I would contribute...6" Fabtech lift. Federal Couragia M/T 35x12.5 on 18" Black Rhino alloys :-)
  • Like 6
Noticing a couple of "performance check" marks here. What that the send-off of your factory rubber? I know that's how mine want to go out.
2.5" Level + 1.5" Body Lift
20x10 ET -24 Moto Metal MO970
33x12.50R20 Federal Couragia M/Ts
No Rubbing / No Trimming
Are these a - 24 offset and which lift kit did you go with. I also want 20x10's on either 295 or 305 but I ordered the 20x9 and 295's with a rough country 4 3/4 combo lift kit. Seems like a big difference between a +18 & - 24 offset. Haven't installed anything yet. Thanks for your reply!
Sent from my SCH-I545 using Tapatalk
Edited by GTALLDAY
Those wheels look good on your truck. This is the best set up you've had by far. Keep it up!
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
