Got my new rims and tires 20x9 fuel maverick rims with a 295/55r20 nitto trail mt. 2.5 rough country leveling kit. Thought i would post some pics of a double cab u dont see to many on this thread. Let me no what you guys think.
What is your wheel offset? Truck looks good.
I would say a 305 would be cutting it real close a 295 fits perfect no rubbing. Im guessing with a 305 u would probably have a little rubbing. You would probably have to do some mods to make them fit.
What offset are your wheels?
Looks perfect IMO....love it!
I will add to the what offset wheel question with a request. Could you take a pic looking straight down the side of the truck showing how far the wheel/tires stick out? From the pics it looks almost flush which is exactly what I am looking for. Thanks.
yes please add pictures cause i am ordering a leveling kit this weekend and wanting to order rims and tires soon. and i am wanting about 1 inch to inch and a half outside the the finder. by the way i have a double cab as well and i must say that truck is like a mustache with titties ( badass)!
My offset is a +20 mm its defly almost flush ill try and post pictures soon of one down the side. Now i need to get mud flaps so i dont chip the crap outta my truck. I think ths is the best compliment ive ever herd for a truck lol.
I’m also trying to find some ideas to offset all the white. Theirs to much white, I’m eventually blacking out the windows and painting my emblems black. I believe on the z71s they have a chrome trim piece down the doors I’m thinking about adding that but painting it black. If anyone has any ideas lto offset all the whitee let me no please.
10527723 810417105669515 5806329778948746072 N
10527407 810417012336191 5831195171569047098 N
10521891 10201205248413565 1820087325 N
10545033 10201205314975229 2131385042 N
10529483 10201205249293587 1140467632 N
I have a few pictures on my profile. Ill have to get a few more pictures down the side.
eqejudep.jpgy3u9eju4.jpg before & after Black Plasti Dip. Stock, all the way.
Personally I'm a fan of the white. But I did plasti dip emblems and bumper and darkened front window
  • Like 3
Im thinking about doing my emblems black. How hard was it to reapply? im not thinking it would be all that hardd. Im just gonna do a few more things to my truck then i think im done i wanna make it look a little less like a work truck with rims its hard to get white trucks not to look like work trucks. But you def have urs looking sharp. Next steps for me are window tint all the way around and i might smoke out the tail lights just a little to break up more of the white also paint my emblems. i cant belive chevy didnt do something like the gmcs with the black fender flares i think that looks awesome and breaks up the white real nice too.
Everybody is going bigger wheels I decided to go smaller. Just can't decide on black rings or polishedattachicon.gifimage.jpgattachicon.gifimage.jpg
Interesting. Did you lower your truck and go smaller?
Personally I like the black rings better from your pics.
I kept the emblems on actually. Just taped off excess and used toothpicks and tweezers to pick off in between letters.
I can feel your jealousy.
Update. Rather than just replace the tire, I ordered a set of LT275/65R18 Toyo Open Country ATII's. Much better now.
DSC 1173
I like the black bead myself…
