18x10 XD Strike -24 on 35s
F47B7C67-2EBB-46EA-898E-4AF78EE70471_zps
6A62E2A6-0B88-4CDC-BFC2-B2EECDF357EB_zps
Rollin' on 35's! Sweet! :thumbs:
Looks great with 18s and all that rubber.
Yes Im glad I went with 18s. Was gonna do 20s but I ended up with this setup because I had seen it before and liked it plus saved a little on tires and wheels compared to 20s
2.5" Level + 1.5" Body Lift
20x10 ET -24 Moto Metal MO970
33x12.50R20 Federal Couragia M/Ts
No Rubbing / No Trimming
Dropping the Sierra off Wednesday morning for a RCX 4 & 3/4 combo lift with basically same wheels as baggedlvintegra, Moto Metal 970's 20x10 with - 24 offset, but went with the 305/55R20 Toyo Open Country AT II's Extreme for the shoes. Installer is skeptic he won't have to trim all night long so I'm hoping I have the same luck as this guy! Wish me well as my baby goes in for the operation. I'll post pics and results asap. ujagy9um.jpgruvatuba.jpg
I had 33 x 12.50s on a stock truck without any level/lift. They didn't rub. Still had at least an inch clearance.
Its the wheels that cause the rubbing. Negative offset is what does it
33x12.5: cooper st maxxx: 305/60R18: (specs: 32.64" x 12.1") (no rubbing)
33x12.5: Nitto terra gapplers: 305/55R20: (specs: 33.07" x 12.6") (rubbing)
Looks like you found a perfect set-up.
I think the inner fender liners are pretty floppy and can rub on one truck and not on another. Also, wheel offset gets more critical as they get larger.
Edited by spurshot
I'm thinking about switching to the AT2s myself so please post pics ASAP so I can see how it will look!
Will do! I saw them mounted last night but not on the truck, still looked sick. Should have the finished product this evening along with pics.
I like that you're doing something other than flat black wheels. I just can't warm up to the flat black wheel look. The wheels just disappear when they're flat black and the style of the wheel doesn't show.
Is that a bronze? Black truck? Should look classy.
Thanks! Yeah, it's a matte bronze on an all black Sierra. Hoping to do something a little different... Original idea was to run with flat black on black, but... eh, let's try something new :)
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
