I should have my kit by Tuesday any pointers to make my install easier aside from what has already been discussed?
Edited by oej1919
get a coat hanger or a metal fish and get ready to push the wires through the firewall grommet.. thats the biggest pita... take the fuse cover off the fuse panel underneath the driver foot area and push the fish from the engine bay toward the inside of the cab first then pull wires through... its the hardest part. BTW the boston acoustics system in my wife's 2013 Camaro SUCKS MY A$$ compared to my kicker.
do you feel like your back speakers are as loud as they were with a stock radio?they sent me back a new amp I hooked it up it sounds the same if you fade to rear the back speakers just do not sound any better they say that it is design the rear speakers are just fillers.they also sent me a new harness I have not hooked up the new harness up because I don't believe that could be a problem since I do have sound from all speakers.bass just sounds unproportional to volume levels when listening at low volume bass overpowers everything.find myself constantly adjusting bass levels and volume levels to find good sound.the guy at kicker has been very helpful though and it sounds pretty good at higher volume I just don't know why they turn the back speakers down so much
I'm thinking I will need to replace all 4 door speakers to try to get the sound I am looking for
Edited by warpedhog
Mall crawler can you fade your eq to rear and reply how loud it sounds. Maybe it's just me but I feel like they have rear speakers turned down and it makes my volume overall sound lower. They say that's on purpose that the front is amplified more to create the "stage".also have you upgraded your door speakers?
  • 5 weeks later...
beeea97c622c5614a80371eb0aece7082a3ff1b5
Good news! Just received mine, and I'm going to install it this weekend... I am now wondering the same thing that another user asked about earlier in this thread- Is anyone running the kicker package (dsp/amp/sub) while using the under seat storage thing in the back?
I'm wondering if the storage box can be modified to fit with the sub. Thanks in advance, and thanks to mallcrawler for this awesome thread!
I've removed the sill plates. There's a box like channel that houses the wires. There's tabs on both sides and you need to disengage the ears at the same time bc if you do one at a time, they'll easily snap back in place. Have something such as a screwdriver lay perpendicular under the top portion or lid to keep it up. You'll need a couple small flat blades to do the prying of the tabs.
Hope this helps.
i installed the power gate system in my truck, like others said the firewall grommet was a bitch. also getting the sill plates off always sucks, so does putting them back on. having a trim panel pry kit would be my recommendation. also start at one end of each, pry it up little and get a look behind where the retention tabs are. then get your pry tool as close to the tab then wedge as you'll bend/break them in no time and they'll never go back in the same.
make sure you test route all your wires too. my sub amp power line barely made it.
to the guy with the under-steat storage: the sub box takes up the entire passenger side under-seat area. you'll definitely need to cut that thing up.
I have the Bose option in my truck (2014 Sierra SLT Crew cab) and wanted a little more thump, so I picked up the Kicker sub upgrade from a store on eBay and installed it and have been very satisfied with it. Here is my post on a different forum for more details with pictures of install if you are interested.
in case you aren't able to see the pics on the other post, here they are...
new in box
wire harness showing wires to tap
wire taps
grommett
finished
Edited by [email protected]
I installed mine a couple months ago the tools referenced from amazon worked great. I ordered something similar prior to install. I am happy with the sound quality as well.
Sent from my SM-G900P using Tapatalk
http://www.walmart.com/ip/Kicker-PT250-10-Subwoofer-with-Built-In-100W-Amplifier/32983978
I installed one of these in my truck last spring. Works great, took me about 2 hrs to install ( I am anal when it comes to wiring ) and never looked back.. Love it, sounds great, fits under the rear seat in my truck ( pass rear ) and screwed the remote infront of the center jump seat. I recently upgraded my head unit ( NX602, guy gave it away for 150$ ) and will be using the pre-amp outputs from the head unit instead of the rear speakers as input ( and a remote turn on wire ) But for 180$ at walmart you cant go wrong. Also upgraded the front speakers to Kicker 6.5's... doing the rears this coming spring along with backup camera.
new in box
wire taps
grommett
finished
I thought it wasn't compatible with the BOSE system. Any difference in how you wired it? Pics of how you wired it?
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
