Last I checked when you tapped into the wiring to install subs on any 6.2 you'd get feedback because of the active noise cancellation these trucks come with. Has there been any workaround this yet?
How did it go for the guys with storage boxes and the kicker?
I cut my box down with a gigsaw.... Followed the form of the sub box. It doesn't butt up to the sub box for fear of rattling. Just off by a hair.
Can you post a pic? Do you have factory or aftermarket like a du ha box?
I will try to take a picture later today....the storage box was installed by the dealer, so I assume it is GM's.
Hello all. I am new to the Silverado and just picked one up 2 weeks ago. I am looking at the amp/sub upgrade from shopchevyparts.com and was also wondering if anyone else has switched out their factory speakers also? I was looking at putting in Kicker 6x9 41KSC694 in the front door and Kicker 41KSC674 in the back door. Does anyone know what size the dash speakers are?
Thanks for answering my questions and for posting your thoughts and experiences of this amp/sub combo.
anyone looking to purchase this kit i ordered the brand new one from gm im in florida i wont ship it
Kicker 200 / 400 Watt Powered Subwoofer and Amp, Double Cab by Kicker® 19303115
whats it worth like 800?
Does anyone that installed this also have full coverage rear floor mats? I didn't think when I ordered the floor mats and now am concerned about how the sub will sound sitting on the mats vs the carpet. Worst case is I don't like it and just take a knife to trim the floor mat around the sub.
I have the full rear seat husky liner and haven't noticed any negative effects. I did put two hard foam spacers inbetween the sub and the mat to ensure there was no additional noise though.
Sent from my SM-G900P using Tapatalk
One more question to use that have the 6.2 and non bose system. Do I have to do anything with the sound cancelling aspect that gets added when you have the 6.2?
Edited by thetruck454
So, I bit the bullet and purchased the Kicker Powerstage Soundgate "kit" from www.shopgmcparts.com They had the lowest price that I was able to find and don't believe any of the BS from AutoAnything about pricematching... They don't do it. They try and use smoke and mirrors, but they fail.
Anyway, the install was easy. My strong suite is not reading directions, but the directions provided were actually clear and helpful. With the helpful information provided within this thread I was ready for the hard part of fishing the power wires through the firewall. That was the most difficult part. However, thanks to the other posters, I thought it went as simple as can be.
The install took about 2.5 hours, simply because it was cold out and I was in no hurry. Oh and somebody routed the cable to the sub woofer backwards. Remember, read the directions...
How does it sound? Frickin amazing. Far better than I expected. My own media is simply awesome, but what impressed me is what it did to XM. I wasn't sure how much it could help the compressed audio from outerspace, but it improves that 110% as well.
The best part about this way of doing things is everything is plug and play and you keep the factory look of the dash...
Andy
So is there no way us Denali owners can use this?
earlier in the thread, I believe somebody has used the Kicker Soundgate along with the factory subwoofer. Somebody correct me if I am wrong, you could use the same signal the factory subwoofer amp receives and split it to the amp of the Kicker.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,313 Guests (See full list)
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
