2014 6.2l gas mileage WOW
dodgehemi0
So I made a pretty long trip I drove from Tennessee to Texas and back. Driving down to Texas I average 20 miles a gallon doing 70 miles an hour. Now coming back is much better story. Here's what the readout on the trucks adaheseh.jpg
But it's a different story when I actually figured the numbers at the pump. This is how I fill up once the pumps clicks I force as much fuel as I can in shaking the truck and what not. 543.9/23.6=23mpg holly cow batman. For these numbers I was running 75 most the way there was lots of construction going on so there were times where I would stop and sitting on the interstate.
Sent from my iPhone using Tapatalk -
  • Replies 32
DO NOT put any more gas into the tank after the pump clicks off. This will lead to issues down the road, I guarantee it.
What do you mean?
That is great fuel economy. I have the 5.3L, but I have found that I get better fuel econ at 75 than I do at 65... strange.
What do you mean?
If the tank is overfilled, liquid gas can make it into the evap system. This can cause the evap canister to fill up and quit working correctly. The fuel tank breathes through this system. So this can cause positive pressure in the tank when fueling, making it hard to fuel, or negative pressure while driving, causing extra strain on the fuel pump.
Good numbers. Did you use premium or regular gas?
Ya 93
Ok thanks
most of the trip was at 75 there was a lot of time sitting on the interstate.
looks good. Check your lifetime sometime on the onstar app. Is usually quite a bit lower.
My onstar app is reading the same
Pretty good numbers there. Best highway trip I was able to pull in my 5.3 as 20.9mpg on a 2 hour stretch in Michigan. But that was in the winter, with below freezing temps, winter fuel, about 70 mph.
Most of my driving is around town with bouts of highway mixed in. Tanks lately have been averaging 17-18 mpg. pretty dang good.
OK thanks. Good to know!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
