Need "Multifunction Switch Instrument Panel" Diagram
i put this in my truck, and no the 4 aux switches are no momentary. they are an on off switch and are a grounding type. look at the diagram of the switch. there is already a ground in the factory harness so u dont have to add one. i used aux one to provide a ground to the relay of my led light bar
What options do you originally have and do they all work? Also, where did you connect the ground of you light bar to for the switch to work in aux 1?
  • Replies 119
i am lucky enough to access to a lot of differrent wiring harness. i took 4 wires from another harness i had with the right size connectors and insirted them in the factory plug. i already had the led light bar in stalled with the relay harness that was provided. that harness used a ground that you attached to the body of your vehicle. i just switched the postive feed for the led on the relay to power the relay and removed the body ground , and the used aux switch to provide the ground to the relay. aux two I now have providing a ground to low power leds in my box. my truck didn't come with factory fogs so that is the next project
23145158 (TC / Dome Light / Blank / AUX1 / AUX2 / AUX3 / AUX4)
23145161
23145162 (Pedals / TC / Dome Light / Park Assist / HDC)
23145163
23145169
23145170
23145171
23145172
23145183
23145184
23145185
23145186
23145190
23145191
23145193
23145195
23145196
23145197
23145198
23145199
23145200
23145202 (Pedals / TC / Dome Light / Park Assist / LDW / HDC / Exhaust Brake)
23145209
23145212
23145213
23145214
23145215
23145216
23145217
Anyone have any of these others to fill? More specifically I am wondering if one exists for TC, Hill decent, bed lights and the aux switches. It would be great to fill this list in though for others looking for their specific switch.
if you go to each model truck in most online parts catalog stores, they will show different options for each truck. it may take a while, but can be done.
I may give this a try tomorrow
23145161 stab cntl switch w/o pwr adj pedals, w/hill decent, w/o park assist
23145163
23145169 stab cntl switch w/o pwr adj pedals, w/o hill decent, w/o park assist
23145170 stab cntl switch w/o pwr adj pedals, w/o hill decent, w/park assist
23145171 stab cntl switch w/pwr adj pedals, w/o hill decent, w/o park assist
23145172 stab cntl switch w/pwr adj pedals, w/o hill decent, w/park assist
23145183
23145184
23145185
23145186
23145188 stab cntl switch w/pwr adj pedals, w/hill decent, w/o park assist
23145190
23145191
23145193
23145195
23145196 stab cntl switch w/o pwr adj pedals, w/hill decent, w/park assist
23145197
23145198
23145199
23145200
23145209
23145212 stab cntl switch w/pwr adj pedals, w/hill decent, w/park assist
23145213
23145214
23145215
23145216
23145217
here are some more. the 1s i updated are in blue with links
i got bored
  • 3 weeks later...
Anyone want to share their thoughts, I am thinking about doing this with part number 23145158. I have traction control, bed lights, and hill decent. The only thing I would lose would be hill decent. If I turn it on before switching them out, I assume I would still have the function, but would not be able to turn it off. Does this seem logical? Would there ever be a reason I would want it off?
I just wonder why they left a blank. There isn't a way to use the blank is there?
Also does anyone know what the loaded 1500 Denali orpanel looks like? Does it also have 7 switches? Or do I need the 2500 panel to get 7 switches?
Hi All, I would first like to thank everyone for all the information posted here, it has been most useful. I think that I have found a solution for using the OEM Momentary switches to control accessories such as light bars. I have decided to use the 23145202 switch as I have the adjustable pedals. This switch gives me 3 open slots to use. The issue with the switches is that being momentary they will not operate a standard relay. Upon searching I found these latching relay boards that come from China and cost $3 each. I picked up four of them to try, they are 12V boards that use a low input, so when the input is grounded, the relay activates and latches, until the input received another low signal. I assembled 3 of them in a case made a harness for them.
I didn't want to order the upfitter switch just for the Aux buttons, I just couldn't justify the extra ~$60 so I decided I would sand down the icons on the switch and make some vinyl icons, it is still a work in progress. But I think it will look good.
I am attaching the schematics for you to reference. At this point I might need to change one thing and wire my low output to the switches to trigger the indicators lights when the lights are active. The light bar I have came with a harness that used a + trigger, so I modified the harness to make it a - trigger, that way any wiring attached directly to the switch is all -
I have yet to remove my switch so I don't know if the wire harness to the switch has all the wires or if I need to find terminal ends to attach all my wires. Can anyone answer that for me? Does anyone have the connector part number? On another note, the exhaust brake switch utilizes another 6 pin connector, information for that connector would be useful as well.
Let me know what you all think.
Post some more pics when this is complete. I was thinking about doing the same thing. Did you cut these or buy them? Are they layered with white below? I'm interested in how they light up as well.
Nice find. Can you share the details of where you found them?
I asked my wife to cut the vinyl with her silhouette, I was amazed it was able to cut them so small. I haven't tested the light output with a white layer of vinyl. I am hoping to just use the black to keep the overall height of the emblem down so it's less noticeable.
Here is a link to the boards, I received the very quickly even though they come from Hong Kong. http://www.ebay.com/ulk/itm/301820150781
Azelkhunter. I'm working on the same thing and believe it or not I bought the same exact latching relay you did as my solution. Still waiting for it though. My question about your wiring diagram is why do you need the second set of relays, the ones labeled out 1,2,3? I'm not an electronic guy, learning as I go so maybe I just don't see it correctly.
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
