WeatherTech Liners are Terrible, What are you doing to solve the probl
I bought a set of floor liners for my 2014 crew cab. The passenger side fits terrible and rides up on the toe board, thus distorting the shape and not protecting the kick panel area. What are you guys doing to solve the problem
  • Replies 63
no such problem with my WT liners....are you certain you purchased the correct set for your truck. am sure others will chip in here but again, perfect fit and functionality for me. no complaints.
Don't they have the little nubs on the bottom anymore. My truck came with them & have never crawled around at all. The little nubs keep mine in position perfectly. Odd!
This is why I wnt went Husky Liners. My wifes Escalade and my truck before my Denali did the same thing. No fix I could figure out, just replace.
Sent from my SCH-I545 using Tapatalk
Contact weather tech that doesn't look right. Have 3 sets (silverado, camaro, and sienna) and they all fit perfect
Ryan
I just installed mine a few days ago. Frankly, I don't see what all the raving is about on these over the years. I've had the Husky liners and liked them better.
Mine kinda look like yours. Not that bad but I just put some velcro on the passenger and that side worked for me GL.... I thought it was cause my baby's car seat pushing up to much to fit.
Contract Weather Tech and see what they could do about it. I went with Husky Liner and I am very happy with them.
I have the WT as well the fronts do not fit perfectly but better than what is shown. I have always used catch all and been very pleased -
Sent from my iPad using Tapatalk HD
Try using a heat gun to form them how you like. Mine were close to yours then with alittle heat, they fit pretty good now.
Mine fit perfect. Had them almost two months no problems.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
