TODAY
idnative1948
Employee number 32038 has left the building at 5:00pm MST, NEVER to return!!!!!
PTL! No more alarm clock, not more work (at work). The honey-do list may be another story though.......
Congratulations! Must be a good feeling, at least until the honey-do list kicks in? LOL
Im 5 years away and envious. LOL
Congratulations. Enjoy.
Congrats. I can't keep this up that long so I think I'll start buying lotto tickets. :lol:
I'm gunning on two retirement's, but that's way ahead into the future, Congrats!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
