While at a complete stop and letting off my brake and reapplying the brake I get this squeak that sounds like rubber grommet is making noise? Have any of you experienced this? 2014 LTZ 4x4
Hello Tacofarmer,
My apologies to hear you are experiencing concerns with a squeaking sound in your 2014 Chevrolet Silverado. I realize that you are seeking feedback from fellow forum members. We'd be happy to further document this concern and possibly reach out to your dealership for a vehicle diagnosis. If this interests you, please reach out to me via private message with your contact information, VIN, current mileage and dealership name. We hope to hear from you!
Andraya
GM Customer Care
I had this issue on my 2007 Silverado. I found that turning up the radio eliminates the problem............
Thanks for the suggestion. I do have the Bose system so I'm sure that's an option, but I don't roll that away. I too had an 07, but didn't have that issue. Had a 2013 as well without any issues.
My '14 5.3L double cab started this around 9000-10000 miles. I fixed it, by trading it in for a 4.3L crew cab.
havent had any issues with mine..i know if i move the brake pedal closer with the power pedal button that it seems more squishy. but no squeaking or movement of any kind.
Interesting. I have a 2014 as well and every time it rains my brake pedal squeaks. Hello, GM?
Hi Mackmo,
We are sorry you are experiencing this concern as well. We'd be glad to look further into this for you and reach out to your dealership on your behalf. Please reach out to us via private message here on the site with your VIN and contact info!
Andraya
GM Customer Care
Hi Mackmo,
I just saw your private message and already responded. I am glad that you were able to figure out how to private message us and I am looking forward to assisting you.
Jennifer T.
GM Customer Care
Wish it were that easy. I actually thought that. So, I took my shoes off. Squeak, squeak, squeak.
WD-40? Usually fixes everything. LOL
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
