Anyone have $94K?
Ryan
I'll sell my quicker car for one third of that, no second thought. :lol:
Edited by SnakeEyes
That is an awesome car for someone who won the lottery. But like Snakeyes points out you can get faster cheaper. I got an high HP truck off Ebay for under 8K. Now if I won the loto that would be in my 36 bay garage.
Edited by KARNUT
2015 camaro5 fest August 6-9 no location announced yet
Ryan
The Z/28 is so awesome
Ryan
Agreed. Curious where the value of these cars will be in 20 years? Obvious unknown, but given the past history where cars that have exotic specs & pricing with limited availability, they only go up.
Even more curious what Chevrolet is going to offer with the 2016's? Will there be a 1LE/ZL1/Z28 variants out of the gate? Can't wait to find out...
Best time to buy a Z/28 will be in about 10 years. Prices WILL drop, since it's not really a limited edition its more like the Camaro's verson of the ZR1. A local dealer has had three on their showroom for about 4 months now. There will be plenty with low miles and kept in pristine condition
There are only a few thousand z/28s made. Back when first offered I heard they may around 20k. They will be worth money
Ryan
Ryan
That's plenty. Like I said, sitting for months around here. I checked, just asking sticker price.
No one really wants one now, unless they are a collector. Its a two seat track car, that will be destroyed by a two seat track focused car that still has all the car creature comforts and only costs a few thousand more(2015 Z06)
Vette can't do this
Ryan
Yeah, neither can a Z/28. :
Unless you do some "modifications" :lol:
Edited by SnakeEyes
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
