I put these in today... could someone bump the mod with your cargo and reverse lights on the same time... please 4e3ce8de9c411d5abeedcdda6fab0ac1.jpg
I can't get this too work for the life of me. Maybe I'm just a fatass
If you're having trouble inserting the diodes, try a different corner within the slot. The connector has a locking tab within it that might block entrance into the slot.
I think I'm just a big dude and can't position myself properly to get in there to look at the slot. I can get the first diode in but to connect it to the middle slot where all the wires are is alittle tougher. Lol oh well.
If you read through this topic, you will see that you are not alone. Different owners have tried different ways to install the diodes. Try them until you find the one that works for you. To start, you may want to unplug the connector if you haven't tried that already.
I have pretty good sized hands, and been working on cars for about 30 years, maybe try a small pair of needle nose plyers to get in and around the other wires?
Edited by 6.2Midnight
It is a tight squeeze to position yourself underneath there. I spent a lot of time in that area for other projects.
man i tried this last night... i could not get it to work!!!..grrr.. i used 2 trying.. and could not get the fogs to stay on.. i did brown with white stripe and brown with purple stripe like op said.. in the brown plug.. i felt like they where pushed down far enough... i'll just have to give it another shot.. .. lucky i got 25 of them suckers! lol.. easy to bend.
    • That's part of the problem...the EGR has already been replaced, and I've already had the complete intake assembly removed, and the EGR passages were clear at that time. That leaves wiring, PCM, or another variable that I wasn't expecting. Best I can tell, it's not wiring or the PCM, so I'm grasping for straws.   The PCM uses the MAP reading to confirm the requisite loss of vacuum in the manifold when the EGR activates. Since that's vacuum related, it involves a lot of other systems which could play a role.   The overall diagnosis has to be considered too. The fuel lines in the intake had rubbed through and were dumping fuel into the intake, drowning the cylinders in fuel, and putting raw fuel into the sump and cat converter. The fuel system has been fixed but the complete path of damage may not be. If the cat was damaged and melted the internals, it could be partially obstructed and also playing into the EGR issue.   I'm retracing my steps; trying to go back to thinking thinking Horses not Zebras based on the clues I've been given. These engines aren't *that* complex.   Could it be, now that the truck is running well, that carbon and crud from being run with the fuel system in disarray is now dislodging and clogged my clean EGR passages where I can't see?  That's what the code is actually saying. The flow is restricted, dummy. Retrace step 1.   I may just need to remove the lower intake again. Before I do that I'm going to try removing the EGR and running the engine for a few seconds to see if it will blow anything lodged in the egr passages out through the open ports.     That's been helpful in the past. For the spider injector, there's no guarantee I'll get a working one. The spider I have seems fine now that the high pressure fuel line isn't making an early delivery via large hole. SO at least I'm not marooned and looking for one of those.   Row52 (dot com) is also a good one for watching for vehicles at local yards.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
