  • 3 weeks later...
didnt read all 31 pages,so maybe its in there... but is there a way to get the FL to come on with the key and stay on with the DRL / LB / HB?... basically on all the time.
Oh ya..its my first post here..
I know my Camaro with the RS package uses the fog lights as DRL lights. But once your headlights turn on you can't have your dog lights on anymore. Same goes if you flash your high beams.
But I bought a plug and play harness that allows you to keep your dogs in all the time. There is no switch to turn them on and off but I guess it's better than nothing. And now they stay on with my headlights and if I put the high beams on as well.
Hope this helps and maybe someone else will chime in with there experience. Maybe someone makes a similar harness for our trucks.
The first page goes into that. The 85 pin pin between what is on and what you want to feed to be on will do that.
It is really worth taking the time to read thru the posts. It will help you understand how and why the resistors are placed where they go and how that makes the functions occur that you desire.
Sent from my XT1254 using Tapatalk
Edited by TxDoc
thx for the help..found what i need on PG4..the 10-22 jump should be what i am looking for. Fogs on with my DRLs and on HIGHS
First post here, but I've been lurking for a while.
I'm a new GMC Sierra owner -- bought a 2015 SLT Crew Cab 4WD two weeks ago and am loving it! I'm coming from a Wrangler Unlimited that I modded heavily so the mod bug obviously has bitten me once again.
I'm wanting to do this mod and I'm curious if anyone by chance has any diodes they have still laying around that I could have? I have a 100 pack in my Amazon cart but that's overkill if there unused ones out there.
Thanks
Edited by kramer2k
Thanks
I've got a couple. PM me your address and will put in an envelope tomorrow.
Awesome! Thanks so much! PM on the way.
In my 2003 Avalanche, this is what I did for the All On High. I also opted to have my running lights come on with my fog lights. Will this work with the 2017 system, if not, what will I need to do to keep everything on when I either flash or turn on my highs, and have the DRL's come on when I turn on my fogs?
As a side note, we replace the white DRL lights with Amber so we know who all is from the site. But, our DRL's come on when we put the truck in drive only.
Here is the link:
http://www.chevyavalanchefanclub.com/cafcna/index.php/topic,60928.0.html
  • 1 month later...
I want this! How?
Sent from my SCH-I545 using Tapatalk
My company, same one that developed this:
wanting some info on this but cant figure out how to PM you
Hizzle3500,
Here is the link to what you are looking for. I have spoke to them before about having my remote make the windows go up, pay good attention to their hours of operation, they are very specific about it. I want to do the radio mod and the windows as well...
http://www.whiteautoandmedia.com/
Back on subject, has anyone tried the #10 & #18 on a 2017 Silverado 1500 yet? If so, are all six lights one when you turn on the high beams? That would be High, Low, and Fog...
With the 16's and 17's, there would only be 4 lights on at any one time with the fogs, whether it be low or high.
But I know what you're trying to ask.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
