Better Front Strut Options?
kd2dwj
Are there any other options other then the factory front struts for our trucks? My truck does get used offroad quite a bit, as well as on the street as a daily, was just looking for an all around better ride, I have the Ready Lift 4 In Lift and I hate seeing the stock black strut in there with it.
Also whats out there for the rear shocks? Not looking to break the bank on this either otherwise I'd of gotten those nice FOX Coil Overs haha
Thanks
King makes a coilover assembly for this truck. Probably Fox too. Both are bound to be colorful if that's your requirement.
Rancho makes a coilover assembly as well. I don't recall the color combination.
Why not just paint the stock coilover?
BTW, they are not "struts". That's like calling a camshaft a crankshaft.
IMO, go with the Bilstein 5100's and not break the bank. Good shocks all around.
Unfortunately the Bilstein's for the front are not out. They have been saying in a couple of months since March.
Sent from the future via a wifi time portal.
That's and the factory spring and perch are all still going to be black.
You do get that shiny piece through the middle though with a pretty blue sticker, ha.
Wonder what they are changing? It looks like FOX, know for a fact Pro Comp and Camburg all use the same ones they did for the 13 model year.
Fox has so much adjustment that it's just a matter of physically fitting with their stuff.
I think Bilstein is doing different valving.
I'm really anxious to see what they come up with. I like their last model's valving in my 08 GMT900. I'm not fond of the valving in my OEM Rancho shocks. They seem to "stack" easily.
Spurshot, what does the term 'stack' refer to in the shock world. Does it have something to do with rebound and losing the control?
I vote with you on the 5100s and agree they must be changing the valves as the 2014s seem to have heaver/stiffer springs.
In the GM marketing crap they claimed the suspension was stiffened by 30% for 2014. I'm guessing the 5100's had to be re-tuned and it's taking forever haha.
I thought they claim the frame was stiffened, not the suspension.
"The coil-over-shock front suspension features aluminum upper and lower control arms on many models that are both lighter and stiffer than previous components, along with front springs are up to 30 percent stiffer than those on current models, for more confident handling."
http://media.gm.com/media/us/en/gm/news.detail.html/content/Pages/news/us/en/2012/Dec/1213-2014-silverado.html
I have the old style 5100's on mine and they aren't bad--overall way better than the Ranchos. I do think they could use a bit more low speed rebound though. If they do that for the 2014's I'll probably swap eventually.
I have an all terrain now with the rancho shocks and struts and they are bouncy. Wait for the Bilsteins. It will be worth the wait.
"Stacking" is a term that refers to the shock absorber effective damping limiting the suspension travel at an undesirable rate, especially when rapid suspension movement occurs.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
