It will cost less than 1k. I love my 6.2L but i can't leave things alone i put a 2" leveling kit and 33" tires didn't really affect performance to much, but would like to get a little extra power. I will do the maintenance myself with a few buddies so only paying for parts and beer.
Do you have previous experience with changing gears? It's a pretty involved process. I've been around it enough to know that it's something left to a professional, haha. And, you're figuring the cost of a tune into your budget, right?
Have you priced them through GM yet? Last time I checked just a Ring an Pinion from the GM dealership was north of 800$ and you are going to need 2 plus the shim kits, crush sleeve, pinion seal and nut at the least. Bearings should all be good still. As far as I know no one makes an aftermarket set for 9.76".
Edit. The front you can go aftermarket for around 350; it is same as previous years.
Edited by CAtaylor
Are their any visual differences we could look for? Some of you guys with post some pics and if you have max tow and 6.2 or 5.3????
But according to the response... all 6.2 and only the 5.3 with max tow.
Here is the axle/differential under my 6.2 with 3.42 gears.
Edited by DCOX
  • 5 weeks later...
Thanks for posting the pic. Unless they look identical, that's the 9.5" rear end. Mine looks exactly the same (also a 2014 6.2 3.42).
Could somebody with the NHT package post a pic of what the 9.76" looks like?
I think you (and I) have the 9.76 axle... I talked to a product rep from Detroit. They said all the 6.2s had 9.76. Not sure of the difference in looks of the 9.76 and the 9.5. More pics would be great.
Edited by DCOX
Yeah, we need pics of a confirmed NHT 3.73 axle. There may have been a change from '14 to '15 as well.
This is interesting I was just under mine and I have a 6.2l 3.73 with NHT. I know I have the 9.76 it was on my build sheet. I was looking because I wanted a new differential cover from PML.
Differential is marked with:
0134
R9652
12 bolt
I have looked high and low for a differential cover without success.
Edited by sugarjohnson
I suspect the 9.76 and 9.5 are one and the same with exception of the ring/pinion set. AAM manufactures the axle assembly for GM, on it's website it lists the same carrier #40090728 for both 9.5 (3.42/3.73/4.10) and 9.76 (3.23/3.42/3.73). Both axle assemblies use the same pinion seal. Gear sets are different part numbers though. Just a guess, the 9.76 is using a HD gear set with a slightly wider tooth on the ring gear to increase contact area.
Wow, so they do look exactly the same. Given all the advertising of the 9.76" GM does I was sort of thinking it would be a beefier housing, maybe larger axles, etc. But if the housing is the same, carriers are the same, bearings are the same, etc, it's really not all that much of an upgrade.
Either way I think this is good news for those looking to swap gears as I would assume the 4.10's AAM now makes should work in either axle. Hopefully anyway.
2011 6.2 with NHT was 9.5". Are you getting confused with year. Maybe the new ones have 9.76" and pre-2014 has 9.5"?
Could have been a change for 15 to handle the lower gear ratios (higher driveshaft torque) behind the 8 speed.
Don't have a pic of it, but on the web from the pinion to the axle tube on pass side it will say 9.50 or 9.76 in the casting.
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
