+1 on the K02s.
I'm using them as snow shoes that won't melt on my annual drive to Florida and provide traction through the Appalachians. And that lake effect snow that NY and PA gets!
The K02s are each over 10lbs heavier than the Continental LX20s and one can feel it. Very slight hum heard if one listens closely with the radio off. No flat spotting, even with recent -6°F weather. Haven't had the opportunity to run them in deep snow yet, and can't wait to do so!
As per the vibration / buffeting issue thread, I did have to work with my dealer to road force balance them to under GMs 15lbs spec for a buffeting free drive. Got them to 12lb, 10lb, 10lb and 8lb.
Sensitive to vibrations, these new trucks are!
How did you like the continental lx20's?? I will need new tires this spring and so far they look like candidates. Most of my use will be on road with dirt trails and light snow thrown in once every blue moon. The reviews i have read have been very positive.
IIRC the 265/70/17 come in at about $137.
I would not buy them again. The fact that my dealer had to replace 6 to eliminate the buffeting (see 'Yukon noise in cabin' thread) is the primary reason. In fact, I also have a post in that thread where I collected customer feedback from various sites - it's not very good on many different vehicles. I'll be replacing the Continentals with Michelin's first chance I get.
Since my last post here, I've had a chance to drive the KO2s in the snow. They're amazing! Excellent traction. I just finished a 1500 mile drive to Florida on them and got 18.2mpg averaging 69mph. At ~10lbs heavier per tire, there is a slight penalty over the Continentals.
Stock picture before I get the RC 2.5 leveling kit and 285/65r20s installed on Friday. Deciding if I want the step bars and valance off or not.
Edited by kgillean
Swapped my Cooper Discoverer AT3's for BFG AT KO2's a few months back. Best decision I made. The KO2 is better all around in every condition. Dry, wet, snow, etc.
Tires fit perfect. I will take some pictures and try to answer some of the measurement questions from above tomorrow.
any rubbing I was looking at this size and I also seen the 305/55/20 on stock wheels and looked good any pics of yours? Edited by Steeks
Sorry, been busy with work. There is minor rubbing on the liner inside the wheel well. Refer to page 7 of this thread for pictures of the area. It takes one zip tie on each side to tie it back to the frame. I will work on pictures tomorrow.
They aren't cheap though. I paid 430 a tire.
Also, here is another reference to them fitting:
http://www.gm-trucks.com/forums/topic/156030-has-anyone-tried-2856520s-under-a-leveled-2014-yet/page-2
Edited by kgillean
Hey guys I just got a new set of BFG AT KO2 275-60-20 on my 2014 Crew Cab. What do you think?
Truck looks awesome. I used this/your pic here to go get my tires; however, after I had them mounted and drove them a bit, in person I felt like they looked smaller than what you have. Luckily I was able to take them back and swap for the taller 275/65, and have been pleased since.
Just had 275/65/18's installed and love them. No life and not even close to rubbing full lock. Can't wait to get to try the off road
Ok will try this again. Just installed 275/65/18 KO2s on my 2016 Z71. Lots of clearance with no rubbing issues. Great ride and very minimal road noise at 70 mph or for that matter at any speed. Look great and will post pics when I get it cleaned up. Rained all day after install.
Got my truck Saturday. Swapped out the GY SRA's for Stock size KO2's.
Wow! It's amazing how much better that looks, even in the stock size! :thumbs:
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
