Finally got into the K02 club! I got a good deal on CL for these Mehtod NV's last Dec but never got around to getting them put on until now. Lost a little power to the extra rotating mass but it was less than I had feared. Rides better than my stock 20s did so worth the trade off!
17x8.5 285/70/17
Good choice! Those methods look awesome with that color!
  • 5 weeks later...
2017 GMC All Terrain BFG KO2 275/60R20 with Motofab 1.5" Level and Front Valance Removed
Day After Tires/Level Front
Day After Tires/Level Side
Day After Tires/Level Rear
  • 5 months later...
Any thoughts on going with a 285/60R18? Costco has that size for a great price over the 285/65R18. I'm wondering if the 1" height difference would be that noticeable. Right now I just have the stock Goodyear HT's.
17x8.5 285/70/17
That stance is killer. I’ve been looking at some method mesh wheels in 17x8.5. I’m leaning towards Ridge Grapplers for tires though. What level kit are you running?
Thanks, hasn’t changed at all from this pic still love it! Bilstein 5100s all 4, on highest setting in front(1.85), stock height rear.
Thanks for the reply. I like the thin profile of those mud flaps as well. What brand are those?
Weather tech, highly recommended! No drilling, took 20ish mins to install.
its what i'm getting when its time to replace.. .i'll do the 60/20... like OP.
On ‎12‎/‎13‎/‎2014 at 10:02 AM, JerryCanada said:
Set of KO2 installed about a month ago. Not as loud as the KO's I have on my work truck. This is 275-65-18 with a 2.5" front 1" rear RC kit.
Nice setup....real similar to mine.  Just curious...are those LT275 65 18 (Load Range E)?  Just wondering how you like your setup...ride, wear, etc.
2016 Silverado 1500
This thread has been very helpful to make a decision on what size to go with.  Here is my setup to help contribute.
Went with the 275/65R20 on a Rough Country 2.5" Level.  I ended up with slight rubbing on the rear of the felt fender liner.
No real comments yet on the setup as I have only put about 30 road miles on it so far.  MPG has definitely dropped off some and the ride is a little stiffer, can feel the bumps/potholes more.
Edited by Deprime
I'm currently running a 275/70r18 on GMC Sierra AT4 wheels. 2.5'' motofab upper strut leveling kit.
Love these tires! 275/60/20
Sent from my SM-G935V using Tapatalk
Nice set up! Did you put any level on up front? Any rubbing issues if not? I’d like to go to this set up but not sure what size tire I’ll be able to clear.
2" level. No rubbing issues at all. I believe I could of went a little bigger without issues.
Sent from my SM-G975U using Tapatalk
    nolankd
    nolankd
  • Who's Online   3 Members, 1 Anonymous, 460 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
