Come do the step light mods on my truck and my brothers. And u can hear the 14" muffler exhaust. Thinking of get a little intake if it really does sound good. We've beer and $$$
Step light mod? Talking about putting the LED strips on the rockers to shine on the steps?
Alright, here it is, everything I've done today. Pretty busy but well worth it. Got it cleaned this morning at the local car wash (did a decent job).
Got back home and started off by replacing the front pads and rotors with Power Stop brakes and rotors severe duty truck and tow model
Moved on to the rear assist springs, easy install. Also hit the u bolts with the impact to make sure they were tight
Went ahead and covered the front and rear bowties with black vinyl, need to redo the rear bc I messed up cutting it so a little gold is showing
And last but not least I finally installed my bumper step LED's! This is my favorite of all the mods I've done so far, it just looks cool lol
This 1. Help us out..
Ok I'll do it. Can't be that hard... i wound like to tie it into the reverse lights.
Hey CJ, do you remember what model spring you bought? Was it this one?
Hellwig Sport Series Helper Springs 1801- HEL-1801
Oh, lol those were a pain. I'd be scared to break y'alls steps
CJ,
How is your canned tune these days? Have you heard a light flapping like sound at all? I seem to have this thing where if I'm cruising at 30 or 40 mph and I give it gas but lightly; I'll hear some kind of rattling/flapping sound and then the engine rev's. I don't know if this existed before the canned tune. I did cut the exhaust valve thingy out when I had my exhaust done so it's not that. I did tune AFM out.
You still running torque management, AFM, and 20% throttle boost?
CJ,
Truck is running better than it ever has! I have not heard any flapping type sound like you are talking about though. I am running AFM off, torque management off, 20% throttle boost, on the trans hard shift setting, as well as it reprogrammed for the 33 inch tires. It is also on the Diablo Flex tune and I run 93 octane in it
Damn; it's weird sound--can't quite place it.
Other than that my truck runs great still.
I can't believe the fuel mileage I'm getting on a tuned truck with 33s, it's on believable! I am averaging around 17.5 MPG on back roads and around 20 on the highway depending on my speed. And now it is a lot more fun to drive now, that's always a plus LOL
Yep! That is what I am getting too.
We're going to Texas next week to visit my family--be eager to see how it does long distance; bout 18 hour drive.
How are those brake rotors treating you? I'm worried with all the rain and moisture in fl that they will warp easily
sent from Florida beech
I've towed a good bit since I put them on, and I've had to slam on the brakes a few times and I don't feel any steering wheel shimmy from what would be a warped rotor. They improved the pedal feel greatly and the stopping power is also a lot better, helps slow these 33's down as if I had stock size tires. Great investment so far!
Nice build! Been awhile since I've browsed this forum, missed it a bunch lol. One question though, I'm surprised you are running those rotors. The drilled/slotted rotors have been proved plenty times it's mainly all for show. Though, the slotted bro's out there prefer, well, slotted rotors for track use since it "cleans" the pad surface upon application. I used to run the same set up as you on my old 06 when I had it, after 25k miles of zero towing and not much hard braking, I noticed the drilled portions had small cracks surrounding some of the holes. Sent pics and email to the company, powerslot???, and they wanted to send me some new ones but I declined and bought new solid surface rotors and some EBC heavy duty pads instead. Not trying to upset you about your purchase or anything, but rather inform you to make sure you check your rotors often so to not have any fatal issues down the road since you tow and such.
Well on my 02 I had slotted and DIMPLED, not drilled rotors. Those were still on there to the day I sold it, around 60k miles on them. I get what you're saying about the drilled portion of the rotors getting cracked, I've heard that before as well. Only time will tell but I can definitely say that they have made an improvement to my braking distance (although that could just be the pads)
Welcome back! I remember you moved to England and got a VW then left us lol
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
