1 hour ago, jimmyboy8301 said:
Yup, BORA 1.75” spacers
What’s your rake like does it sit higher up front with the Bilstein ?
i'm 1" higher in the front with the bilsteins on the 3rd setting (1.25")
Just Got some 22" Snowflakes put on. Have no idea why picture is upside down. Even rotated before inserting and still upside down.
Edited by LoganX
I see you did the reverse gravity mod too, nice!
You live in Australia?
Just got mine after 14 years with a Titan with 228K on it.  Love the truck !!
Well, I just happened to see a MiG 28 do a...
 Uh, sorry Goose. WE happened to see a MiG 28 do a 4G negative dive.
 Where did you see this?
 Uh, that's classified.
 Started up on his six, when he pulled in through the clouds, and then I moved in above him.
 Well, if you were directly above him, how could you see him?
Because I was inverted.
repost fail... my bad
Edited by Ak_grown
Wtf?
Top Gun
Sent from my SM-G950U using Tapatalk
I know what it’s from, it’s application here doesn’t fit though
EXACTLY!!!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
