Stock as can be, second day of owning it, today is the third. Just a matter of time for mods to come along, waiting for the new truck smell to wear off...
looks good - great color
Is that the RC? Nice set up. Also are you leveled?
I'm not sure what brand it is. I bought it from the dealership like this and they told me it was a 2.5" leveling kit.
Dont think I posted here my updated Suntek Paint Protection Film in Matte
Edited by AllTerrainX
Very nice, I was thinking of wrapping mine in flat black myself... I gotta ask, how much price wise, and how long to do it?
Edited by 6.2Midnight
Its a paint protection film so its a bit more expensive then the vinyl. Got it done for $5000 (originally quoted $6500, I talked them down. Other quotes I got ranged from $7k-$12k!!!). Took the installer 5 business days.
Went with the PPF because it protects against damage caused by rocks, salt, insects, and other road debris, etc, better then vinyl. Vinyl is purely cosmetic, no paint protection characteristics.
Suntek film comes in clear and matte. Went with matte because I love flat black! Turns any glossy paint and covers it and makes the paint look matte. So if I ever decide to remove the film, I can always go back to gloss. Might get it done on my silver car. I also had them put some clear film on the headlights, fog lights and tail lights, to help protect them from damage and fading. Also clear on the door sills to prevent scratches from my dogs or people getting in and out. I am OCD lol.
Hope that helps.
Check out Suntek's site. Watch the video of them taking a wire brush to the film on the car and it self heals.
Features and Benefits Video
Site
http://www.suntekfilms.com/paintprotection/suntek-window-paint-protection.aspx
Hope that helps.
Site
looks good
Huh..., never heard of it, but sounds like something worth looking into. Thanks for the information.
Nice! Do you plan on doing the back bumper as well?
I've looked at them for a color matching option.
considering it. really dont mind the chrome on the rear bumper.
2016 Silverado 1500 Custom Double Cab
Bought it Nov 16th, already added DeeZee Step Bars, AVS Vent Shades,
Black Bowtie Package and an Alpine PWE-S8 Powered Sub.
Edited by bryceramos
How are you liking the 305/55/20s ko2s? Did you add the rear block?
Steeks - I am really pleased with their performance especially in the snow. They are 4-season rated and well worth the cost. I did the Rough Country 2.5" level/lift which included rear blocks.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
