Does this work?
In a rented 15 and it is nice but how do you get them back up without holding the button for each? Driver is auto up. So far it's the only feature I wish I had in my 14 however it is a lower trim level so maybe there are other goodies I haven't seen.
  • 2 months later...
This opens and closes the outside mirrors on my 2014. Can't do anything with the windows. Does it do both on the 2015s? Or do the mirrors not "Auto" Open/Close anymore?
If I remember right using the lock instead of unlock folds the mirrors in and out on mine. Just checked and using the unlock rolls the windows down
Mirrors fold in and out. Windows go down, but not up. I also like how it is possible to turn on the ac and heated seats with the remote start. I wish I knew that sooner.
  • 9 months later...
If I only has the choice of being able to get the windows to go up or down with the remote i would have picked up.... Would be nice to notice it might rain and put the windows up from inside the house... of if they are down you could put them up and lock the doors and put the alarm on for the night. Could really care less about down.
X2 Disappointed they won't roll up by holding lock button like in some vehicles
how do you turn the Ac/Heat on? I don't think that's possible. I know how to do the mirrors and Windows but not the seats.
If you have the option enabled in the personalization menu, the seat will heat or cool when truck is started by remote. The indicator light on the dash will NOT turn on, and the seat function will shut off when the truck is started.
From 2015 OM:
The heated or cooled seats will not
turn on during a remote start unless
they are enabled in the vehicle
personalization menu. See Remote
Vehicle Start on page 2-6 and
Vehicle Personalization on
page 5-46.
Don't have my truck yet, but I read this in an online 2015Silverado 1500 OwnersManual.
"On some models, press, release
and then press and hold unlock to open
all of the windows. Pressing the
button again will stop the windows."
I think it is for the LTZ models, not for LT's. FYI, not working on my 14 LT.
