5.3 with 3.08 vs 3.42
ChevyBrad1500
Best bet is probably to trade your truck in for one with a 3.42, the swap is very expensive for a 4x4
I think he would lose more than it would cost to swap gears even for a 4x4. Assuming all you have to do is change the ring and pinion and not the whole diff. It should only be about $500 for the ring and pinions for both axles and then whatever the labor would be. I'm guessing it shouldn't be more than $1,000 for it all.
Well if that is the case I stand corrected! Maybe I should have a 3.73 put in my truck!
I just drove my Truck yesterday the first time, after is has been arrived in germany.
We had a 300 Km trip on the German- Autobahn and i thought it would be a nightmare, but it was not.
For shure the tranny shiftet uphill sometimes down to fourth gear, but thats ok when you try doing 120- 150 Km/h.
The truck needed about 12,5 liter of gas for 100 km distance and thats just fine.
The power from standing stop is not really big, but as soon you get it goinig, it revs up and pushes quick to 159 Km/h. At this speed the speedlimiter hits in and the fun is over.
I think in my way of driving a good tune by Lew/ Diablew will do its job. and the first things will be to turn the speedlimiter off!
For pulling a trailer it´s another story, but again, it has 6 gears and a tow/haul button, so let the tranny do its work. Just watch the trans.temp.
Anyway, it a very nice Truck i´m happy.
and the gears can be swapped maybe in future.
have a save trip all of you and i give more informations after i put on the tune
so long Franky
That's what I plan on changing mine to. I hate the 3.08s.
I have a 3.42 in my truck now and it's plenty snappy with my 4.3L but, I'd like to have a 6.2 w/ a 3.73 better :-D
The first Diablo Tune is now on (with our Euro Super Plus 98 octane gas in the tank) and there is allready a good difference what i feel.
It seems to push the Truck a lot better from standing stop, the lazy acceleration is gone. it revs up quickly!
the throttle response ist way better, but still not perfect. maybe Lewis can change that also for me.
The V4 mod turns on fairly often when cruising, so thats working fine.
Soon there will be the first datalogging and i´m looking forward what Lewis can make out of it.
We will see how the 3.08 gears get going then.
keep on this theard!
so long Franky
I have a GMC 3.08 and a Chevy 3.42 both 2014. Daily driving it's not noticeable but I'm not flooring it from light to light. I don't tow more than 5,000 lbs. so that's not an issue either.
In that case send me your 3.42s and I'll send you the 3.08s in mine after I get them swapped. Won't be 3.73s but good enough lol.
LOL! I was hesitant about the 3.08's but the truck is my wife's and she's very happy with it. She came out of a 2012 GMC 1500 CC w/ 3.42's.
Well that sure defines it. AAM updated their site to include the 9.5" 12 bolt. 3.08 to 3.42 requires a different case. Probably not worth the effort unless going to the 4.10.
  • 2 years later...
Sorry to bring up an old thread, I was just reading through threads containing 3.08 gears. My 2016 2LT Z71 Double Cab 4x4 5.3 6 spd with 3.08 is my first real "truck." I've had smaller mini trucks like a Dakota, and a K5 once, so I never done a lot of towing with my own personal truck, just others. My truck has the trailer rating of 6,200 lbs, so definitely not the optimal towing platform "on paper." I will say this, whenever I need to trailer, the truck is no slouch. There are times just driving to and from work that I wish I had a higher gear to improve acceleration, but it absolutely isn't a deal breaker. I've hauled three cars in the piedmont of North Carolina, so some hills and some flat land, and it honestly pulls like a 3/4 ton. The truck is very smooth and acts like it likes to have a load behind it. Two of the cars were around 3,000 lbs, and the other was a 4,500 lb Mercury Marauder land yacht. The trailer I pull is every bit of 2,000 lbs empty, a 16' Hudson Equipment Trailer. I've also had 2 tons of brick chips on the trailer as well, so that would be 4 instances I've had 5,000-6,500 lbs behind the truck, and it does just fine. Don't get caught up with the hype of having to have the best of everything on the order sheet. Now, I'm not saying don't opt for a 3.42 or 3.73 truck, but if a great deal comes on a 3.08 like I got, don't be scared of the high ratio. If you occasionally pull like I do, and use the truck like a half ton is intended to be used (a homeowner/light duty truck for occasional hauling in my eyes) you'll be just fine. Hope that helps.
Also, if I do highway trips around 50-65mph, I'll see an average of 22.5-23 mpg no issue, and I don't baby it. In town I rarely see lower than 17 mpg. That's running 87 octane, no tune, no intake, I just have a glasspack muffler in place of the stock. Towing 6,000 lbs, I would usually get 12-13 mpg.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
