Hopefully your system has leak dye in it still? A black light will help find the dye at the leaks.
Yea condenser leak is probably the most common issue on the 2014-2018 generation 1500s.
Next common would be the one hose off the compressor or the compressor itself. 2014s used to crack that hose near where it attached to the compressor if I'm not mistaken.
EDIT: Here's the PI for that line cracking - temp.xml It can spray dye all over the hose and compressor if it happens.
Check the a/c condenser.............they are notorious for cracking at the pinch weld. Look through the grill on the driverside. There's a small tack weld. If I remember right if you hold up a black light the refrigerant will glow if the weld is cracked
