2006 upgrade audio, retain steering wheel controls
I have a 2006 Silverado LT Crew Cab, Stock Stereo, W Bose speakers and steering wheel controls, XM, OnStar. I'm looking to replace the unit with some aftermarket with DVD and NAV. I wish to retain the steering wheel controls with the change over. And what about retaining the rear entertainment option (access the stereo controls to the rear seats thru the control in back of center console).
Any comments, suggestions, or advice from others who have done or had this done on their truck would be greatly apprieciated!
I just purchased a isimple gateway, HD radio and Bluetooth with GM wireharness but now after reading how you need to scrool thru menu items on the deck head to access the many different add ons, I think a simple aftermarket double din or even a slide out screen might just be the ticket.
You need an adapter to make everything work (Bose, Steering Wheel Controls etc...). Not sure about the rear entertainment stuff though? I know Crutchfield.com has everything you need for the radio and to make everything else work with it.
Thanks for the advice guys! and kudos to the people on youtube for the vids for all the dash and steering wheel r&r! Great stuffs!!!
Tomorrow I get the LED's installed then on to audio / video projects.
