I would not compare the fox 2.0 to a 5100.
5100 digressive, non rebuild-able, zinc coated brushed metal finish (corrodes fairly quick in extreme weather)
fox 2.0 progressive, rebuild-able, billet aluminium, zinc plated double clear coated
I wouldn't compare them either just based on price. A pair of 5100's for the front only costs $180.
A new eibach spring as well, in addition to a larger diameter shock body. I think a fair comparison is the 6112 to fox 2.0...the Fox 2.5 and icons and kings are in a different league.
I guess when you compare the fact that they are both 2.0" shocks, and the price for the hardware/top mount and eibach springs, they are similarly priced. To me the fox are much more appealing. I think that bilstein should be selling their 6112's assembled to. Making the customer use their stock hardware and top mount is kind of a slap in the face for the price they sell for.
So what I am gathering is Bilsten 5100's and the way they are developing the 6112's so there is no need of installing an aftermarket UCA... Have I come to the correct conclusion or would I be better off buying a new UCA? I would be using the stock 20 inch wheels with 275/60/20 tires...
If you raise, you'll always be better off with a new UCA. However, the Bilstein 5100 and 6112 will be designed to work perfectly with stock UCA's, as is the Fox 2.0 except for those with aluminum stock U/LCA's
Crap so that means if I would buy the 16 AT with the aluminum UCA's when the 6112's come out I will need to replace the U/LCA's. Dang. I was trying to avoid that...
No, you misread. The Bilstein's both 5100 and 6112 will work with stock control arms. You would likely benefit some from getting new UCAs, but it is in no way necessary
If anyone is interested I have a brand new in the box set of Pro Comp SS struts for sale. I purchased these with the intent to install but decided to go with the Fox 2.0 set up.
These are adjustable just like the 5100 and have pretty much the exact same ride characteristics.
I purchased for $210 and will sell for $150 shipped.
http://www.4wheelparts.com/Suspension/Pro-Runner-SS-Monotube-Shock-Absorber.aspx?t_c=1&t_s=90&t_pt=3306&t_pn=EXPZX2108
What's up fellas i have a quick question I bought a 2" kit for my truck to level it with the rear I wanted to know what would be or preferred size and tires to go with
Thank you
I wonder why fox makes the 2.0 different for the aluminum suspension. do their coils come in contact with the control arms some how? Only difference between aluminum and steel arms is the ball joint tapers.
Edited by projectsummit
This has been discussed in length, I have a thread on here that explains the differences between the two arms.
The 6112 is pretty much identical to what comes on the Tacoma & 4Runner Pro Models. The Tundra PRO has a different one-off shock which has a reservoir on it, while the aftermarket Tundra 6112 does not have one.
Does the 6112 for this application have position sensitive valving like the Tundra Pro shocks?
I think the 6112 is a 2.5 diameter shock at least thats what I'am reading.
Edited by southern_sierra
We were talking about comparing the 5100's to the fox 2.0's
The 6112 will not require new arms, but it is always a worthwhile upgrade.
Your posts are not very clear, so I am not sure what you are referring too.
The Fox 2.0 is a 2" Diameter shock. The 6112 is a 2.65" Diameter shock. The 5100 is a 2.0" diameter shock.
The Fox 2.0 and Bilstein 6112 come with new springs, the 5100 does not.
From over a year of testing the 6112 and from personal experience with both systems, the Fox 2.0 are no where near the performance level of the 6112, but are a big upgrade from the 5100, which is much better than stock.
The cost is very reasonable for what you get, a 2.65" shock that costs half of all of the other 2.5 options out there. If you want a billet top hat, threaded shock body and all that race level awesomeness you should be looking at a Fox, King or ICON 2.5" coilover system.
    250.3k
    chfkief
    chfkief
  • Who's Online   4 Members, 0 Anonymous, 1,490 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
