Also the more I drove the truck the more I felt the front was over sprung in the front on the highest setting due to the compression of the spring in the highest setting.
The springs are no more compressed in the highest setting as they are in the stock configuration.
I would disagree the difference in ride was very noticeable.
That is due to the shock dampening, not spring compression.
This debate should have a simple, factual explanation but this is hard to find. Here is a link that will either help or add more confusion/misunderstanding. http://www.gm-trucks.com/forums/topic/185075-coil-spring-compression-and-lift-101/. I ended up buying $35 MotoFab 1.5" spacers as I wasn't convinced Bilsteins was a better way to raise the front of my vehicle.
Does anyone have links for the best deals on these? Looking for all (4). Thanks!
Well I will be the first to admit I was wrong about this one. It doesn't make 100% sense to me but I get the jist of it. This is also kinda helpful. http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
I was surprised to read this too. Quoted from the Bilstein link:The lift on the 5100 Series leveling shocks is achieved by increasing the preload on the factory coil. By adding more preload, the shock is designed with more rebound damping as compared to the O.E. or standard aftermarket replacement shock.
You might get a little rub on the sway bar...I had 305/55r20 nitto Terra grapplers on stock suspension as well as the 5100's at the highest setting...those tires are probably as close to a 33/12.50 as you can get...they where on stock rims with a +27 offset. The both rubbed on the sway bar and it also rubbed a little on the fender liners at stock height.
The 305/55R20 Terra Grappler G2 specs out as about 1/2" taller but a little over 1/16" more narrow than the 33/12.50 Ridge Grappler. Pretty close.
Quick question, can a guy run the 5100 on the bottom "stock" setting and a 2" spacer? Or would there be any problems due to the 5100 being slightly longer than the stock shocks? Would like to get something done to my truck asap as I have new wheels waiting to go on... Thanks!
I heard from a popular automotive shop in Texas that this is their preferred method of leveling. I don't fully understand why but I am inclined to believe this would give you a nicer ride. I often read about people complaining about a harsh ride from Bilsteins at max setting but seldom a complaint from people with 2" spacers.
CAN ANYONE BACK THIS UP??
im thinking 1.25" moto fab with 5100 on lowest setting??
I pm'd him, and he was just referring to running the spacers as opposed to the bilstein shocks at top height. Not the spacers WITH bilstein 5100s at stock setting. But nobody seems to have anything to say so I am going to try it, back my 5100s down to stock setting and run my 2" rc spacer.
Sorry if I wasn't clear. The information I received, as I understood it, was to run the Bilsteins at stock height and use spacers to create the lift. I chose just to go with spacers because I was happy with my stock shocks. I originally thought that Bilsteins method of creating lift was superior (raising the spring perch) but it isn't IMO. Bilstein is arguably a better quality shock than stock and combining these (at stock height) with spacers, I believe, is the best of both!
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
